-> Plumbing Forum |
| Author |
Message |
Any_help_welcome Junior Member
Joined: 14 Nov 2007 Posts: 6 Location: North West London
Posted: Wed Nov 14, 2007 3:44 pm Post subject: Fitting radiators into a bay window |
I have just has some radiators fitted into a bay window and do not feel they have been fitted correctly. I do not have a sound basis for this except my "feeling" so any advice would be appreciated.
There are 3 radiators in the bay.
Starting from the right hand side of radiator 1.
There is a pipe at ground level from the floor going into in then two coming out at the other end at the top and bottom these are both joined to radiator 2.
Radiator 2 has these 2 pipes going in and coming out at the other end again one at the top and one at the bottom both going into Radiator 3. Radiator 3 has two pipies going in and one coming out a ground level.
Before we used to have 3 radiators with a single connecting pipe at the bottom level and a thing at the top to let out air. Are these fitted OK? Am I just being too old fashioned. Also they look just dreadful!
| Back to top |
Hoovie Devon DIYer
Posted: Wed Nov 14, 2007 3:55 pm Post subject: |
Any chance of a picture? or even a drawing?
_________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
ultimatehandyman Site Admin
Posted: Wed Nov 14, 2007 3:57 pm Post subject: |
I have attached a picture of what I think you have described and then a picture of how it would normally be done-
| Description: |
| This is how your bay radiators have been fitted, I think? |
| Filesize: |
9.59 KB |
| Viewed: |
1444 Time(s) |
| Description: |
| This is how a bay is normally plumbed with three radiators |
| Filesize: |
9.26 KB |
| Viewed: |
1444 Time(s) |
_________________ DIY | DIY Video |
| Back to top |
Posted: Wed Nov 14, 2007 4:09 pm Post subject: |
| Yes the first picture is how they look. Is this OK?
| Back to top |
Posted: Wed Nov 14, 2007 4:20 pm Post subject: |
| Any_help_welcome wrote: |
| Yes the first picture is how they look. Is this OK? |
Well it's not the way I would do it and I have never seen it done that way before
I can't see the logic behind putting the extra pipes at the top of the radiators
| Back to top |
Posted: Wed Nov 14, 2007 4:25 pm Post subject: |
Me neither!
What I would like is the set up in picture 2. But the builder insists he is right and I am fussy. I think the double pipe thing means that if the middle heater gets an air lock I will never be albe to bleed it to get rid of it.
Please if you could suggest a good logical arguement I can put to him it would be appreciated. Otherwise I suppose I can get a second plumber in to remedy the situation but I imagine that this may well be costly.
| Back to top |
Posted: Wed Nov 14, 2007 4:36 pm Post subject: |
| Theoretically if he just removed the top pipes and put in those silver bolt things would all be OK ?
| Back to top |
Posted: Wed Nov 14, 2007 4:41 pm Post subject: |
| Theoretically if he just removed the top pipes and put in those silver bolt things would all be OK ? |
Yes, although I am not sure how he has connected the pipes into the radiators.
Your best option is to let some of the professionals on here have a look and read their replies tomorrow
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Wed Nov 14, 2007 8:30 pm Post subject: |
both ideas would work
_________________ Decking |
| Back to top |
Posted: Thu Nov 15, 2007 10:23 am Post subject: |
I think it would look a lot neater if the pipes were just at the bottom though!
| Back to top |
Posted: Thu Nov 15, 2007 11:18 am Post subject: |
I do feel much better now. Thank you.
Am I right ot assume that there will be no effect on the efficiency of my heaters with this set up then.
I will however go with the traditional set up as it just makes me feel better.
| Back to top |
Posted: Thu Nov 15, 2007 11:34 am Post subject: |
I will however go with the traditional set up as it just makes me feel better. |
As far as I can see it won't effect the efficiency, it will just effect the overall look of it.
The rads will look much neater if the pipes are just at the bottom.
| Back to top |
Posted: Thu Nov 15, 2007 7:04 pm Post subject: |
i agree for asthetics just at the bottom would look better but it will work fine
| Back to top |
bathstyle BATHROOM DESIGN AND INSTALLATION
Posted: Thu Nov 15, 2007 7:45 pm Post subject: |
| I would have thought that the middle and certainly last radiator would take a lot longer to heat up than the first as you have essentially created a minature one pipe heating system in the bottom pic.
| Back to top |
Posted: Fri Nov 16, 2007 12:56 am Post subject: |
| bathstyle wrote: |
| I would have thought that the middle and certainly last radiator would take a lot longer to heat up than the first as you have essentially created a minature one pipe heating system in the bottom pic. |
yes but it will still work
| Back to top |
