| Author |
Message |
kissbigal
Posted: Sun Jan 08, 2012 10:46 am |
| Newly registered Member |
Joined: Fri Oct 29, 2010 8:08 pm Posts: 43 Has thanked: 2 times Been thanked: 0 times
I am replaycing a mechanical timer with a drayton programmer. so I order the correct one, does a 3 wire or 4 wire instalation refer to how many wires come from the pump. I can't remember!
| Top |
thescruff
Posted: Sun Jan 08, 2012 11:01 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39982 Has thanked: 187 times Been thanked: 2113 times
A programmer and a timer are Different.
Best to post all the details about the boiler and controls plus what you intend to replace them with.
Makes and models please.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
gas4you
Posted: Sun Jan 08, 2012 2:20 pm |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3577 Has thanked: 51 times Been thanked: 230 times
| Top |
register or
log in
kissbigal
Posted: Mon Jan 09, 2012 9:06 am |
Perhaps I discribed it incorrectly as a timer, I am replacing a danfloss unit, the type with a dial that you turn to set the time and lugs that turns the heating on and off. I fitted a drayton programmer on my daughters has c/h and it has been fine, so I've already bought one for my heating. I have a boiler, h/w tank, 2 motorised valves, danfloss 4 wires pump. I know I will have to fit a junction box.
| Top |
register or
log in
thescruff
Posted: Mon Jan 09, 2012 9:15 am |
| OAP |
But does the boiler, motorized valves and pump have a make/model.
Can you also explain a 4 wire pump, far as I know they don't make one for the domestic market.
Every boiler, programmer, timer etc is different, therefore the information requested is a must have.
| Top |
register or
log in
kissbigal
Posted: Mon Jan 09, 2012 9:49 am |
sorry scruff I was getting mixed up with my daughters system :oops Boiler is a stelrad ideal classic, 1 honeywell sundial 3 position diverter motorised valve (4 wires), wilo pump gold?(3 wires) and the danfloss 102 mechanical programmer.
| Top |
register or
log in
D Hailsham
Posted: Mon Jan 09, 2012 12:23 pm |
| Senior Member |
Joined: Tue Oct 02, 2007 11:45 am Posts: 786 Has thanked: 5 times Been thanked: 56 times
Do you have a room thermostat and a thermostat on the side of your HW cylinder?
Which model no is the diverter valve - V4073 or V4044?
| Top |
register or
log in
kissbigal
Posted: Tue Jan 10, 2012 5:23 am |
I have a basic honeywell tank and room stat (can't see a model or number)20years old.
| Top |
register or
log in
kissbigal
Posted: Tue Jan 10, 2012 8:20 am |
I can't see a number on the motorised valve the label on it says sundial system Y 3 position diverter valve
| Top |
register or
log in
thescruff
Posted: Tue Jan 10, 2012 8:53 am |
| OAP |
Guess who's making hard work of this What is the model of the new Drayton programmer.
| Top |
register or
log in
kissbigal
Posted: Tue Jan 10, 2012 10:56 am |
Been like this since I had a stroke. The programmer I want to put on is a Drayton MK4 LP112
| Top |
register or
log in
thescruff
Posted: Tue Jan 10, 2012 1:18 pm |
| OAP |
I have added the corresponding Drayton terminals to the Danfoss.
6 - L 5 - N 1 - 3 2 - 4
you don't need any link wires.
Set the programmer to fully pumped.
| Attachments: |
| Top |
register or
log in
kissbigal
Posted: Fri Jan 13, 2012 6:05 am |
Thanks Scruff I'll give it a go
| Top |
register or
log in
kissbigal
Posted: Mon Jan 16, 2012 1:04 pm |
On the Drayton programmer there are 6 terminals L and N. I cannot find a diagram that shows where the 4 corresponding wires go from the programmer to the numbered terminals in the junction box
| Top |
register or
log in
thescruff
Posted: Mon Jan 16, 2012 1:19 pm |
| OAP |
Are you moving the old Danfoss then. I marked the Drayton terminals on the drawing.
| Top |
register or
log in
