Ultimate Handyman Home
Fitting kitchen door.
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum
Hampstead
Junior Member
PostPosted: Tue Oct 16, 2007 6:12 pm    Post subject: Fitting kitchen door. Add User to Ignore List Reply with quote
Hi, I have fitted an integrated washing machine in my kitchen and I'm trying to work out how to fit the door.
The washing machine has captive nuts to fit the hinge to, but I have no idea how to fit them to the door. The normal rebate is not there. The doors are dead flat.
I'm guessing I'll have to use a router. Are there special bits for this?
If anybody knows of a video tutorial, I'd really appreciate it.
Back to top
PostPosted: Tue Oct 16, 2007 6:24 pm    Post subject: Add User to Ignore List Reply with quote
Hi, and welcome Hello
I have never fitted an integral machine before but I know how you make the holes for using concealed hinges. Take a look here- http://www.ultimatehandyman.co.uk/diy/decking/handrail_fitting.htm
You will see that I have used a pillar drill and a hinge cutter bit, there is 2 sizes of these 35mm and 26mm so make sure you get the right one-
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=11596&ts=58951
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=13419&ts=58991
By using a pillar drill you can use the depth stop to make 100% certain that you will not come out the other side of the door.
Hope this helps a little.
DIY | DIY Video
Back to top
owen
PostPosted: Tue Oct 16, 2007 6:58 pm    Post subject: Add User to Ignore List Reply with quote
normally integrated appliance doors fit using special concealed hinges, which you need to drill the door for exactly as UHM describes above.
what you need to be careful of is that the holes need to be in the right place, as there is not usually much adjustment on the hinges.
your washing machine should have come with a template or instructions showing exactly where the hinge holes need to be drilled.
Back to top
Hampstead
Junior Member
PostPosted: Tue Oct 16, 2007 7:15 pm    Post subject: Add User to Ignore List Reply with quote
Ah ha - that looks like what I need. Will they fit in a router?
Back to top
PostPosted: Tue Oct 16, 2007 8:01 pm    Post subject: Add User to Ignore List Reply with quote
I think they will fit in a router, if I remember rightly the shaft on both size cutters is the same size.
DIY | DIY Video
Back to top
Hampstead
Junior Member
PostPosted: Tue Oct 16, 2007 8:25 pm    Post subject: Add User to Ignore List Reply with quote
wish me luck - I'm a terrible DIYer, but I can't get anybody to come out and do the job!
Back to top
PostPosted: Tue Oct 16, 2007 11:07 pm    Post subject: Add User to Ignore List Reply with quote
Use a cordless drill and blip the trigger. Punch a centre point which will help you align the cutter correctly. You will have more control with the cutter in a cordless and less chance of going through the door.
Back to top
carhartt kid
PostPosted: Wed Oct 17, 2007 9:52 pm    Post subject: Add User to Ignore List Reply with quote
The pro's use a forstner bit. Available from screwfick's for about £5-10??? I use the budget set and resharpen them when needs be. Just measure up and mark a centre point with a bradawl. Then whack the right size one of these in a battery drill and cut away. Stop before you go to deep and drop the hinge in a few times to check it sits flush!!!
http://www.screwfix.com/search.do;jsessionid=IPKL4T5XNQDD4CSTHZOSFFI?_dyncharset=UTF-8&fh_search=forstner
http://www.carhartt.com/
Back to top
dirtydeeds
Craftsman Carpenter
PostPosted: Wed Oct 17, 2007 9:54 pm    Post subject: Add User to Ignore List Reply with quote
try fitting the ...........................................
im looking for an pc acceptble word here
try fitting the bstads when its a repair and there aint no instructions
the customer has called you in because he, his wife, the "boy" the entire family, his mates and "three tradesman" have all had a go at it
then he tells you.................. its only a small door
finding a pc word for that guy.......................
it isnt possible
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum All times are GMT
Page 1 of 1
