It is currently Sat Apr 20, 2019 11:35 pm
PostPosted: Sat Oct 01, 2016 1:11 pm
Has thanked: 16 times
Been thanked: 1 times
I have had to make doors for kitchen cupboards. All went well until I drilled the hole in the door to take the concealed hinge and I don't want to make the mistake again.
Looks as if I drilled the holes to far from the edge of the door but I cant understand why I got it wrong. For 26mm and 35m hinges, how far from the edge of the door should the centre of the hole be? Lets say the cupboard carcass is 18mm thick and I want to have the door hide the carcass.
for 26mm hinge on an 18mm carcass, I drilled the centre of the hole 22mm from the edge of the door. When I did this, the door has to sit a long way off the carcass so it can open without the door hitting the carcass. Is this right?
I need to drill holes for 35mm hinges on an 18mm carcass. How far from the edge of the door should the centre of the hole be?
thank you in advance
glassescase
PostPosted: Sat Oct 01, 2016 1:32 pm
Has thanked: 415 times
Been thanked: 1549 times
22mm sounds about right for a 35mm hinge, (could be 21.5 or even 23mm - can't quite remember).
I've never used 26mm hinges, but if 22mm is right for a 35mm hinge I can see why it would be wrong for a 26mm hinge.
Find a bit of scrap and practice.
PostPosted: Sat Oct 01, 2016 2:27 pm
why would it be wrong of a 26mm hinge? the hinge seemed to have 9mm from hinge to edge of carcass then 13mm to the centre. what have I got wrong?
glassescase
PostPosted: Sat Oct 01, 2016 2:54 pm
Has thanked: 656 times
Been thanked: 1861 times
For a 26mm hinge the centre point should be 1/2 the cup radius plus 5mm. So this would be 13mm plus 5mm to give 18mm in from the door edge as your centre. :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : glassescase
PostPosted: Sat Oct 01, 2016 4:18 pm
glassescase wrote:
why would it be wrong of a 26mm hinge? ................................. what have I got wrong?
glassescase
It leaves too much door *hanging oot the back* when you open it - that's why you've had to bring it off the carcass to make it work.
PostPosted: Sat Oct 01, 2016 4:47 pm
Has thanked: 234 times
Been thanked: 192 times
You can get jigs for them with the tool
PostPosted: Sun Oct 02, 2016 9:03 pm
thanks dewaltdisney and ayjay i'll try 22mm
glassescase
PostPosted: Thu Nov 01, 2018 10:12 am
Has thanked: 2 times
dewaltdisney,
Is that the same formula regardless for an 18mm or 15mm carcase?
Steve
PostPosted: Fri Nov 02, 2018 8:35 am
I am a bit out of touch, as I understand it the hinge mortice is the same for 18mm carcases but the mounting plate attached to the carcase is 0mm instead of the usual 3mm plate for 15mm carcases. I am not sure if there are better designed universal plates these days?? I am sure one of the guys on here will clarify?
Painting with BIN
PostPosted: Sat Nov 03, 2018 8:32 pm
I use this jig £1.99 never fails.
https://www.ebay.co.uk/itm/Jig-Template ... 1065829906
PostPosted: Sat Nov 03, 2018 8:33 pm
Same here
PostPosted: Sun Nov 04, 2018 9:11 am
The important point here is the 18mm carcase wall. Is the 35mm door mortice in the same position or slightly over? You will see I suggest the 0mm hinge plate mount to compensate for this thicker cabinet wall. What is the thoughts on this thicker carcase?
Painting with BIN
For this message the author dewaltdisney has received gratitude : SteveJB
PostPosted: Sun Nov 04, 2018 7:59 pm
What DWD said....
