Ultimate Handyman Home
Fitting Auto Reverse sensors on Honda Civic 2004
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Vehicle maintenance & Repair
Fearn
Junior Member
PostPosted: Sat Apr 05, 2008 11:56 am    Post subject: Fitting Auto Reverse sensors on Honda Civic 2004 Add User to Ignore List Reply with quote
:Can you advise the best way to pick up the live and earth wire for the auto reversing sensors control unit on a 2004 Honda Civic.
Back to top
PostPosted: Sat Apr 05, 2008 1:46 pm    Post subject: Add User to Ignore List Reply with quote
How long are the wires for the sensors?
If they are long enough to reach to the dashboard then you should be able to easily pick up a live and neutral there, perhaps one of the wires that feeds the stereo!
DIY | DIY Video
Back to top
Hoovie
Devon DIYer
PostPosted: Sat Apr 05, 2008 2:56 pm    Post subject: Add User to Ignore List Reply with quote
Fearn - where are you planning to site the control unit? usually these would be fitted somewhere in the boot area area as otherwise you would have to run 4 or 6 sets of wires - one pair from each sensor to the control unit and I doubt they are long enough anyway scratch
The typical installation is a control unit that gets tucked away behind a bit of trim somewhere in the boot - with all the sensor cable pairs going to them.
The earth can come from virtually anywhere - find a screw or bolt that goes into the carand piggy onto that.
Power bets to come from the +12V that goes to a reversing light - that way the sensors are only active when in reverse.
If you have a unit that just buzzes, it will be loud enough when in the boot I bet!
If you have a unit with a countdown display as well, that I would have thought will take power from the control unit anyway?
If not and it does need its own power, then often the easiest place to get an ignition controlled +12V is to tap into the suply to the cigar lighter.
Back to top
Slugs
Junior Member
PostPosted: Tue Apr 08, 2008 9:04 am    Post subject: Add User to Ignore List Reply with quote
Your local dealer may have a template if you haven't already got one for drilling the holes in the bumper - Don't want to get that wrong!
DIY. I'm lovin it!
Back to top
Fearn
Junior Member
PostPosted: Tue Apr 08, 2008 9:18 am    Post subject: Fitting 4 renerse sensors on Honda Civic 2004 Add User to Ignore List Reply with quote
Is it the same as the 2006 model where the hole markings are on the back of the bumper if so do you remove the bumper in the same way. If this is not the case what are the sensor spacings,
Back to top
Slugs
Junior Member
PostPosted: Tue Apr 08, 2008 9:25 am    Post subject: Re: Fitting 4 renerse sensors on Honda Civic 2004 Add User to Ignore List Reply with quote
Not sure. I don't have much experience with Hondas unfortunately.
If they do have markings that's even better! Seems like Honda do things properly! Thumbright
DIY. I'm lovin it!
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Vehicle maintenance & Repair All times are GMT
Page 1 of 1
