-> General DIY forum |
| Author |
Message |
Ron Manager Junior Member
Posted: Mon Aug 18, 2008 8:51 am Post subject: Fitting anchor bolts correctly? |
Hope the following question doesn't sound stupid, but I've just used anchor bolts for the first time and I need to be sure I've done it properly. Made sure I drilled (into brickwork) to the correct size and depth, but when it came to attaching the nuts I was surprised how much the threaded shank withdrew from the fitting before the nuts began to tighten. All seems tight and secure now, but is that how the things normally work? Need to know it's OK because its a shelf for a quite heavy TV, so many thanks for any advice or help. _________________ Small boys in the park. Coats for goalposts. Enduring image, isn't it? Marvellous. |
| Back to top |
thescruff Senior Member
Posted: Mon Aug 18, 2008 8:54 am Post subject: |
And what would the wall be made of. ???????? _________________ Scruff |
| Back to top |
Posted: Mon Aug 18, 2008 8:55 am Post subject: |
Thanks for the quick reply. It's brick and plaster. _________________ Small boys in the park. Coats for goalposts. Enduring image, isn't it? Marvellous. |
| Back to top |
Posted: Mon Aug 18, 2008 8:58 am Post subject: |
In brick they should be fine. _________________ Scruff |
| Back to top |
Posted: Mon Aug 18, 2008 9:00 am Post subject: |
Hey, top man! Even though the shank withdrew like that? _________________ Small boys in the park. Coats for goalposts. Enduring image, isn't it? Marvellous. |
| Back to top |
Posted: Mon Aug 18, 2008 9:06 am Post subject: |
The shank will come out as the collets expand, provided the wall is of a sound material the are a good fixing _________________ Scruff |
| Back to top |
Posted: Mon Aug 18, 2008 9:14 am Post subject: |
That's brilliant, Scruff. Many thanks indeed for your help. It's guys like you who make these forums work. _________________ Small boys in the park. Coats for goalposts. Enduring image, isn't it? Marvellous. |
| Back to top |
