It is currently Sat Feb 24, 2018 9:20 pm
Visit Thermo worx
PostPosted: Sun Jul 16, 2017 3:22 pm
Has thanked: 2 times
Hello!
I really need some advice.
I have been given a VELFAC 200 sliding door which appears to require that the frame be fixed on all 4 sides. I'm fitting this in the back of an old double garage, single story, so I'm very tight on space between the top of the lintel and the bottom of the trusses so the lintel is going to be literally sat right above the new door.
Issue is, I can't drill a concrete lintel so how do I fix the frame across the top? Has anyone tackled this before?
Thanks.
PostPosted: Sun Jul 16, 2017 3:38 pm
Has thanked: 953 times
Been thanked: 1776 times
Why can't you drill into the concrete lintel?
PostPosted: Fri Jul 28, 2017 7:18 am
Been thanked: 3 times
Glue it with a polyurethane sealant such as Tiger Seal. It won't move then.
For this message the author themoog has received gratitude : multiman
PostPosted: Fri Jul 28, 2017 7:30 am
Has thanked: 12 times
Been thanked: 177 times
You can drill into the lintel for your head fixings. Preferably use an SDS Drill and try to avoid reinforcement (which in a Spanlite lintel is likely to be central).
davyp1
For this message the author davyp1 has received gratitude : multiman
PostPosted: Fri Jul 28, 2017 4:54 pm
Errrrm I don't think so. It needs a secure fixing directly into the lintel above and down each side.
You can then seal round the entire frame with expanding foam.
For this message the author steviejoiner74 has received gratitude : multiman
PostPosted: Sun Jul 30, 2017 10:34 pm
Has thanked: 763 times
Been thanked: 343 times
Stevie I was told a while back you shouldn't screw the frame into the lintel unless absolutely neccessary i.e if it's a long window and the frame moves in the centre. I guess it's something to do with the drainage but not sure. Can you confirm this is not the case?
PostPosted: Sun Jul 30, 2017 10:54 pm
Dunno who told you that cause it's utter nonsense!
A window/door/patio set doesn't have any drainage point at the top anyhow. All the weep holes on the frames are at the bottom.
For this message the author steviejoiner74 has received gratitude : Argyll
