It is currently Wed May 22, 2013 6:20 pm
PostPosted: Sat Jan 15, 2011 7:00 pm
Hi
I'm thinking of installing the wooden wickes loft ladder as it get good reviews.
It requires a ceiling hole width of 545mm, but the space between my joists is 555mm.
So, I'm wondering how I cope with the 10mm gap between the frame and the joists? I guess padding it by fixing a piece of plywood to one of the joists would do the trick?
PostPosted: Sat Jan 15, 2011 7:18 pm
Has thanked: 16 times
Been thanked: 454 times
put a link in for the loft ladder.........................there is different ones, so it will be better to know which is the one you want.
After all, you may not have to do anything!
PostPosted: Sat Jan 15, 2011 8:06 pm
Has thanked: 301 times
Been thanked: 1006 times
Try this one from screw fix..
http://www.screwfix.com/prods/55681/Acc ... oft-Ladder
although if this is the wickes ladder you are referring to
http://www.wickes.co.uk/Timber-Loft-Lad ... nvt/191204
It shouldn't be a problem fitting it..
"thescruff is correct"
PostPosted: Sun Jan 16, 2011 10:19 am
Hi
Made a mistake in my original post, the wickes one was the one I was thinking of fitting before I realised the frame is 570mm wide. I only have 555mm between the joists so I don't see how I could fit it?
Here's the one I was thinking of getting:
http://www.laddersandscaffoldtowers.co. ... 545mm.html
PostPosted: Sun Jan 16, 2011 5:44 pm
Has thanked: 8 times
Been thanked: 10 times
Use packers all around then trim it.
