-> Carpentry/Joinery Forum |
| Author |
Message |
Fraser Junior Member
Posted: Mon Oct 01, 2007 10:56 am Post subject: Fitting a floating mantlepeice |
I am intending to fit a oak beam (4"x5"x40") as a mantle on a chimney breast (by the way the fire is not used).
What's the best way to do this considering the timber is solid?
I was thinking of using 3 or so short, large diameter dowels screwed to the masonary then drilling holes in the rear of the beam and gluing the beam onto the dowels (does that make sense?).
Anyone done anything similar or know of any other methods??
Cheers
| Back to top |
Wood Magnet Senior Member
Posted: Mon Oct 01, 2007 6:30 pm Post subject: |
What do you mean by "Dowels", if you mean wood dowels it's a no no, you need threaded steel bar for the "Dowels" and three should be o.k. but personally i always err on the side of caution so i would use four.
_________________ People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's. |
| Back to top |
Hitch Senior Member
Posted: Mon Oct 01, 2007 6:42 pm Post subject: |
Steel studding fixed into the wall, 10mm diameter, Drill the holes in the shelf to suit, but nice and tight, and push over the studding.
You could drill the shelf slighty larger and put a bit of gripfill in the holes to secure it. But it wont be coming off again.
_________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Posted: Tue Oct 02, 2007 8:48 am Post subject: |
Cheers for the suggestions. I did mean wood but I'll change that for steel bar now
| Back to top |
Posted: Tue Oct 02, 2007 4:26 pm Post subject: |
Your welcome Fraser, and thanks for replying.
| Back to top |
Posted: Wed Oct 03, 2007 12:14 pm Post subject: |
Okay, I've got myself some 10mm steel studding.
What's the best way to fix it to the masonary? The threads on the studding don't look like they'd bite into wall plugs - my initial plan was to use fischer wall plugs (60mm long) into 12mm drilled holes in brickwork (covered in plaster by the way) and then screw in the studding, but now I'm not sure?
| Back to top |
Posted: Wed Oct 03, 2007 5:13 pm Post subject: |
Drill a hole stick some gripfill in and then the rod,
once it's set you're ready for the timber, then just repeat
the process.
| Back to top |
Hitch Senior Member
Posted: Wed Oct 03, 2007 7:30 pm Post subject: |
Yes, as its only a shelf, some gripfill in the holes will suffice. Take care not to drill right through the brickwork, of it will just keep pushing it out the back
Drill the holes as square as possible.
Id be inclined to fix the studs in the wall, then drill the shelf to suit, incase you need to move any of the holes.
| Back to top |
Posted: Thu Oct 04, 2007 9:24 am Post subject: |
| Nice one, I'll post a pic once I have done it.
| Back to top |
ultimatehandyman Site Admin
Posted: Thu Oct 04, 2007 9:31 am Post subject: |
| Fraser wrote: |
| Nice one, I'll post a pic once I have done it. |
Nice one
Good luck with it
_________________ DIY | DIY Video |
| Back to top |
Posted: Thu Oct 04, 2007 4:42 pm Post subject: |
| Fraser wrote: |
Looking forward to it Fraser.
| Back to top |
| Back to top |
Hitch Senior Member
Posted: Mon Oct 15, 2007 9:35 pm Post subject: |
Nice one Fraser
| Back to top |
Posted: Mon Oct 15, 2007 11:34 pm Post subject: |
Well done Fraser ,and thanks for showing the picture.
| Back to top |
Posted: Tue Oct 16, 2007 3:43 am Post subject: |
Well done Fraser- looks great
| Back to top |
