It is currently Thu Feb 09, 2012 9:27 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Fri Sep 03, 2010 8:09 pm
Has thanked: 2 times
Been thanked: 1 times
Hi All
Going to have a bash at tiling around kitchen from worktop to wall cupboards and also extractor/cooker area. I have the tiles which are 'bumpy plain white' from Wickes, measuring 20cmx20cm. I intend to use white grout.
The area is only 3/4 sq m.
What grout/adhesive do i need ? Ready mixed or powder...
What size spacers do i need ??
What size trim do i require ???
Also where is the best place to purchase items ????
Cheers
PostPosted: Fri Sep 03, 2010 9:23 pm
Been thanked: 320 times
Certainly not Wickes for tiles lol........too late now, good luck with them. Although, as long as they are not in blue boxes with Wickes labelling you may be ok.
You will be ok for a tubbed adhesive with those sized tiles.
Just as easy to direct you to Topps tiles, as anywhere.
1 tub of adhesive. 2.5 Kilo of powdered grout. 2.5mm spacers. Trim will be a couple of mm bigger than the tile thickness.
Topps will be Bal products which are good. Nichols and Clarke do Nicobond which is also good.
PostPosted: Sat Sep 04, 2010 10:51 am
Has thanked: 16 times
Been thanked: 55 times
Whats wrong with them?
If at first you don't succeed - remove all evidence that you tried.
PostPosted: Sat Sep 04, 2010 3:00 pm
Beachcomber..................The only thing wrong with Wickes tiles is that I was unfortunate enough to have to use some that the client supplied on a recent bathroom which I did. They don't cut cleanly (and that is with just under £300 tile cutter) the ceramic peels off along the cut, some only snap along part of the score line and this leaves you to snap the rest off. All in all they saved by buying cheap crap tiles but it cost them an extra days labour for the tiling.
Oooops, nearly forgot, they are very brittle too.
PostPosted: Sat Sep 04, 2010 6:34 pm
Has thanked: 151 times
Been thanked: 509 times
When I did the bathroom tiling in my previous house I had no problems at all with wickes tiles...on a "plasplugs" cheapie tile cutter...
Perhaps ROC was just unlucky??? dodgy batch??
PostPosted: Sat Sep 04, 2010 11:53 pm
These were their own branded tiles.
PostPosted: Sun Sep 05, 2010 12:22 pm
Must admit, I've not had that much trouble with them - they are very brittle making curved cuts tricky but other than that they've not caused too much bother.
Although I do dtotally understand the but-clenching panic you feel when a customer says 'it's ok, I can supply the materials'!
PostPosted: Thu Sep 09, 2010 9:38 pm
Has thanked: 136 times
Been thanked: 194 times
To be honest I would not recommend Topps for a DIY'er as the addys are way over priced for BAL. Topps have a habit of marking up the addys and grout to Joe public, fine for tiles, poor for addy
Professional Kitchen & Bathroom Fitters | Master Painters and Decorators | Brighton & Hove
PostPosted: Thu Sep 09, 2010 10:10 pm
Mr. Grumpy
Been thanked: 32 times
for 3 or 4 m2 you can get a small bag of Mapei adhesive from Screwfix, its handy
Must admit, I was happy with Wickes tiles, managed to get curved cuts first time, perhaps its was the specific tiles, dunno.
I found topps very expensive for the trim and BAL SBR & APD, a lot dearer than else where although they do have a good range of trims
