Ultimate Handyman Home
Fibres
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
Matty A
Junior Member
PostPosted: Sat Aug 09, 2008 1:15 am    Post subject: Fibres Add User to Ignore List Reply with quote
Hi any one know what the the fibres are called that you can add to a finish plaster mix or where i can get them?
Back to top
thescruff
PostPosted: Sat Aug 09, 2008 1:26 am    Post subject: Add User to Ignore List Reply with quote
Horse hair Laughing before the plasters wake up. Thumbright
Scruff
Back to top
izalarfin
PostPosted: Sat Aug 09, 2008 10:46 am    Post subject: Add User to Ignore List Reply with quote
Thumbright Laughing
a cheap wet brush cussing
http://www.buildinglime.co.uk/plasteradditives.html
or a Google search on goat or horse hair for plastering should give you more suppliers.
why would you want to add it to a finish plaster mix ?.
Back to top
Matty A
Junior Member
PostPosted: Sat Aug 09, 2008 5:42 pm    Post subject: Add User to Ignore List Reply with quote
I have a ceiling to plaster it is the largest i have done and im only a novice and i was told it gives about an extra 10 minutes dryin time and also prevents cracks appearing.
Back to top
izalarfin
PostPosted: Sun Aug 10, 2008 6:34 am    Post subject: Add User to Ignore List Reply with quote
I was told it gives about an extra 10 minutes drying time.
well I haven't heard that before. I have only use hair in the backing coats with lime putty plaster.
If extra time is what you need, scaffold the room out so you have a raised deck to work from, use a spot board to take your plaster off
and get a mate to mix for you or at least someone to wash out, together that will save you about half an hour each mix.
hair is very hard to add to a mix without it balling up in lumps ( fur balls ) Bang Head
how big is the ceiling ?.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
