It is currently Thu May 24, 2012 1:38 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 13 posts ]
 Post subject: Fencing
PostPosted: Wed Jan 04, 2012 11:34 am
Has thanked: 8 times
Been thanked: 3 times
due to having most of my garden fence wrecked with the high winds yesterday, I am looking to build a new fence. What is the preferred/up to date method/materials to use these days, is it just concrete in your treated posts etc.. or do people recommend concrete posts and gravel boards etc.. or any other recommendations ?
Cheers, John
 Post subject: Re: Fencing
PostPosted: Wed Jan 04, 2012 12:11 pm
Has thanked: 17 times
Been thanked: 264 times
I would bite the bullet and put concrete posts with gravel boards in. Expensive now but you know that the posts will not rot and you will be digging out in a few years time. I would stagger the post run to avoid having to dig out the old post concrete so you are digging fresh holes for the new posts. :thumbright:
For this message the author dewaltdisney has received gratitude : jmcp
PostPosted: Wed Jan 04, 2012 3:37 pm
Hi DWD,
got plenty of slack for moving the holes back 18-24 inches so clashing with the original poles shouldn't be a problem. My garden runs at quite a slope, I'm guessing at about 8-10 degrees so I need to try and trawl the web to see some examples of how it would look running/staggered down a slope.
Cheers, John
PostPosted: Wed Jan 04, 2012 3:48 pm
Has thanked: 15 times
Been thanked: 160 times
Use arriss rails and feather edge boards, much stronger and better looking.
You can get 3m rails, so a lot less posts and site them to suit.
For this message the author cotswold builders has received gratitude : jmcp
PostPosted: Wed Jan 04, 2012 8:10 pm
Been thanked: 43 times
3m rails can sag in the middle, You can get dwarf posts to support the middle, but I'd just stick with 2.4m rails. This will also let you follow the lay of the land more easily as you can change angle of the rail at each post.
You can get concrete arris rail posts, but i've never used them.
If you are prone to high winds, it might be worth considering an open picket type fence which would allow the wind through. Depends on how much privacy is needed.
I am not a pro.
For this message the author jg has received gratitude : jmcp
PostPosted: Wed Jan 04, 2012 8:36 pm
Thanks Cotswold and JG, I will investigate those options as I have never heard of Ariss before. Bloomin wind is wild again tonight, just been out and emptying my garden before all the furniture ends up flying out into the street.
Cheers, John
PostPosted: Wed Jan 04, 2012 8:43 pm
Has thanked: 11 times
Been thanked: 116 times
This is the style of fencing that Cotswold & JG mention
Looks like this from the rear - the arris rails are the horizontal rails between the posts.
Cheers,
Darren
Property Refurbishment & Maintenance Dorset
For this message the author darrenba has received gratitude : jmcp
PostPosted: Wed Jan 04, 2012 10:25 pm
Thanks Darren.
On the first picture, what is the base as it doesn't look as if the boards are going all the way to the ground, they seem to be slotting into something ?
Not sure this style of fence would be any good for here due to the potential wind issues. My fence fell apart at the posts, approx 6 or 7 posts all snapped due to the pressure applied by the wind, although it had been up for about 15 years which isn't too bad.
Cheers, John
PostPosted: Thu Jan 05, 2012 7:34 am
Has thanked: 166 times
Been thanked: 612 times
jmcp wrote:
Thanks Darren.
They're called Gravel Boards.
PostPosted: Thu Jan 05, 2012 8:52 am
If the wind in your location is a major issue then you need to look at "hit and miss" fencing which allows the wind to blow through but gives you some privacy as well. Something like this.
Cheers,
Darren
PostPosted: Thu Jan 05, 2012 10:18 am
Been thanked: 69 times
Or use thicker uprights. Yours were probably 3"x3" and partially rotten after 15 years. If you want or need stronger use 4"x4" posts. These are nearly twice the strength of 3"x3". If you need real strength use railway sleepers as posts.
Mike
PostPosted: Sun Jan 15, 2012 9:37 am
Been thanked: 10 times
Hi, If your garden is on a slope I'd use pressure treated 4X4 posts, will look nicer than the concrete posts in my opinion.
Featherboard looks nice but the wind can't get through it so i wouldn't reccomend that either.
You could go for standard screen, double sided screen (100m slats vertical), ranch stlye/double ranch style (3600X150mm horizontal), scalloped screen or chevron.......there is loads you can try like using a gravel board or capping.
As long as you use at least 75mm rails and no more than 2m centres for your posts. Fencing rails are usually 3600 (3.6m) long so with your posts in at 1800 (1.8m) centres it will be plenty strong as long as you dig your holes 2ft deep for a 6ft fence and use at least a bag an a half of postcrete (if you get high winds I'd use 2)
Good luck!
PostPosted: Sun Jan 15, 2012 10:00 am
My arris rail fences are done with 5x4 posts, If I were specing them, I'd use 6x4
Standard fence panael on 3x3 posts is no way near as strong.
You either need something that will stand up to the wind, or something that will let it through.
With the open fence types you need to consider what's on the other side of it, if there are pants which will forever be growing through the fence, it could get very frustrating.
I am not a pro.
