It is currently Mon Feb 18, 2019 10:42 am
PostPosted: Wed Jun 27, 2018 11:09 am
Has thanked: 1 times
Sorry if I have posted this in the wrong section...
I have a flat roof extension at the rear of my property and have just had the roof deck replaced which is a 24mm ply deck, the sheets from the old one looked more like a book than a sheet of ply due to delamination with an EPDM membrane covering it.
The rotten timber was caused by the fact that although there is a gap between the insulation above the ceiling and the roof deck (there is also a polythene covering over the insulation) there is no ventilation or airflow, so as a result the ply ended up absorbing enough moisture to delaminate.
I would like to install a couple of vents (preferably circular) along the fascia but am worried that water will just blow in through the vents and under the roof deck resulting in the same problem or worse, I've already had the bathroom ceiling fall down due to this issue!
Can anybody recommend a good fascia vent that will allow air flow underneath the roof deck without allowing water to be blown in?
There is also a tiny puncture in the EPDM membrane literally smaller than the diameter of a pencil, is there an EPDM friendly sealant or adheasive I can use to cover this? I have some general purpose exterior sealant or sanitary sealant but not sure that this will be suitable to use on the rubber roof membrane.
Thanks in advance.
PostPosted: Wed Jun 27, 2018 4:34 pm
Has thanked: 1529 times
Been thanked: 3848 times
:welcomeuhm:
Pics please for part one.
Part 2 Google EPDM pond repair kits (seriously)
For this message the author wine~o has received gratitude : davet101
PostPosted: Wed Jun 27, 2018 7:17 pm
Thanks for the response,
Picture (should) show the fascia board which I want to put the vents on, just had a fight with the attachment function! Please excuse the state of my pipe lagging...
Had never considered a pond EPDM repair kit, I take it that'll be OK getting hot in the sun given that it's normally used underwater?
File comment: Fascia board to be vented
PostPosted: Wed Jun 27, 2018 7:30 pm
Looks like you are trying to put vents in the sides. You want vents on the front/low ends if at all.. :scratch:
PostPosted: Wed Jun 27, 2018 8:01 pm
Yes thats the side of the extension, it's one structure which spans across my neighbours house too.
The fascia at the end has a gutter mounted on it so surely I can't put a vent in there?
Chose this section as this was the spot where the old roof deck had been most badly affected by the sweating insulation underneath.
PostPosted: Wed Jun 27, 2018 11:32 pm
Has thanked: 3 times
Been thanked: 135 times
if the new roof needs ventilation then it should be through ventilation.
look up diagrams of cold roofs and warm flat roofs and see which kind you have.
ventilation is usuly built in as the roof is constructed, not afterwards.
can i see three flat roofs?
some more photos of the front and other side and top surface of the roofcould help.
i take it that pitchedroof vents allowed water into the loft and on to the bathroom ceiling?
