It is currently Mon Mar 25, 2019 8:28 pm
PostPosted: Tue May 22, 2018 9:53 am
Has thanked: 9 times
Been thanked: 10 times
Hi.
Just a quick question guys. Had a new consumer unit and some wiring work done 6 months ago. Had wiring put in place for an extractor fan when I got round to doing a second bathroom. Anyway wiring was meant to just be connect up to isolator switch and all good.
I wanted a basic fan with no over run so the wire is 2 core as don't need perm live and is junction boxed from bathroom light.
Anyway to cut a long story short the fan I bought states require inline fuse 3amp. I have read that quite a few folk ignore this as it's pointless and just do the isolator switch, but I have bought and isolator with switch with a 3 amp fuse.
Just want to check the wiring is right.
On back of isolator is
L1 L2 N off
L1 L2 N on
Then fuse next to it is
L out
L in
Do I take supply into L1 on and N, loop L1 to L in and then do same for load on L1 out?
PostPosted: Tue May 22, 2018 6:48 pm
Approved Electrician
Has thanked: 170 times
Been thanked: 589 times
Do away with the fan isolator and just use a 3A switched fused spur - that will provide your isolation.
For this message the author OnlyMe has received gratitude : ashleywood.ash
PostPosted: Tue May 22, 2018 11:22 pm
I couldn't find a 3 amp switched fuse anywhere only 13 amp.
So got this https://www.qvsdirect.com/excel-3-pole- ... gJgVPD_BwE
PostPosted: Wed May 23, 2018 8:41 am
Ahh I take it as there is no permanent live as it is not a timer fan then I don't need an isolator. I'll just fit a fuse then and out a 3 amp in
PostPosted: Wed May 23, 2018 7:10 pm
You can use the fused isolator. Run the switched live through the fuse and then through the isolator. I was assuming that you had bought two seperate items.
