-> Electric Forum UK |
| Author |
Message |
SBL Junior Member
Posted: Fri Oct 03, 2008 2:22 pm Post subject: External Wiring (Lighting) |
Not really a lighting question per se so think this is the right forum......
OK.
Am experienced at household wiring but have never wired any external circuits before so would like some info to avoid any problems.
Am planning to wire two external lights in yard with internal switch, will take feed off internal lighint circuit, can do this ok but need to know recomendations for the external part of the circuit.
So far I intend to use the black 20mm PVC conduit (rigid shock proof) to house external wiring with bog standard 1.5mm cable (all conduits will be at least 2.5m from ground and I think black conduit is UPV resistant). I need to know what I should use for the internal/external juntions and any external juntion boxes.
I see 2/3 way junction boxes but am not sure these are suitable for actualy housing junctions/terminals etc.... Should I buy specifix junction boxes/terminals and if so for this kind of use what IP ratnig shoudl I be using.
Also, for connection conduit, bends etc.. what gromits do I need and is there anyhting else I should eb awrae of.
Thanks!
(also, who's moved the keys on this keyboard.... :) ) |
| Back to top |
IDontBelieveIt Senior Member
Joined: 29 Jul 2008 Posts: 934 Location: North Hampshire
| Back to top |
SBL Junior Member
Posted: Fri Oct 03, 2008 8:00 pm Post subject: |
| Excellent. Thank you! |
| Back to top |
Rich-Ando Approved Electrician
Joined: 24 Mar 2007 Posts: 2481 Location: Derby, Derbyshire
Posted: Sat Oct 04, 2008 9:01 am Post subject: |
| i would be interested in seeing what type of lights you were considering using. this may make a difference on how you supply them. |
| Back to top |
