It is currently Wed Jul 18, 2018 6:06 am
 Post subject: Evolution rage 3b help
PostPosted: Thu Jul 03, 2014 8:22 pm
Has thanked: 4 times
Hi all, I've just bought a rage 3b mitre saw and was wondering if anyone had one and could give me some tips. I also bought the revolution mitre stand and was wondering how you secure the back.
Also the roller supports are slightly higher then the saw bed at minimum making it cut on an angle, anyone else had this?Image
PostPosted: Thu Jul 03, 2014 8:25 pm
Has thanked: 673 times
Been thanked: 1934 times
how much are the rollers too high if a small amount [a few mm] then you could place washers between stand and saw base
are you sure its mounted properly with all spacers/other bits in place??
PostPosted: Fri Jul 04, 2014 12:22 pm
Yes I've just been informed by evolution tools that it is the wrong stand for the saw even though on the box says with fit any rage mitre saw, was thinking of putting a board underneath the saw to support the back which will also raise the base
PostPosted: Sun Jul 06, 2014 6:46 pm
Also just come across thisImage
Is the wood too big for the saw or is there a way around it?
PostPosted: Sun Jul 06, 2014 6:57 pm
Has thanked: 990 times
Been thanked: 1848 times
Looks like it. Tbh if you're looking to get into carpentry there's no polite way of saying this but those evolution saws are pure junk,the blades only good for cutting up pallets and they aren't very accurate.
But at 50 quid you can't expect much.
You'd be better getting an entry level makita or dewalt,it'll last a lot longer and won't frustrate you with lack of power,accuracy and cutting limitations.
One of these would be a good starting point
Makita LS0714 240v 190mm Slide Compound Mitre Saw - Ffx
www.ffx.co.uk/.../00088381057707%20240V ... lide%20C...
MAKITA LS0714 190mm Slide Compound Mitre Saw All 4 rails ride on linear ball bearings for extremely smooth and precise operation. Makita LS 0714 Can cut ...
PostPosted: Sun Jul 06, 2014 7:29 pm
Has thanked: 397 times
Been thanked: 1405 times
Maximum cutting capacity 50 X 120 mm, ( you should find it in the specs, with the destructions).
http://www.evolutionpowertools.com/down ... 3b_eng.pdf
PostPosted: Sun Jul 06, 2014 7:33 pm
Has thanked: 97 times
Been thanked: 296 times
Something not right in this picture, the blade guard should be able to move away from the cut, have a look at the same saw in screwfix and the accompanying pictures should tell you what is right.
I am concerned that you are a power tool novice as you are experiencing this problems with a circular saw, perhaps you should get on-hand advice from an experienced person to oversee your attempts.
http://is.gd/4cqZEm
PostPosted: Sun Jul 06, 2014 10:54 pm
is the blade gaurd grounding on the wood??
PostPosted: Fri Sep 12, 2014 4:28 pm
Has thanked: 1317 times
Been thanked: 1220 times
What size of timber is that?
I have this saw and to be honest it's great for cutting 3*2 and 4*2 timber
Check out our nominated charity
