It is currently Tue Feb 19, 2019 9:42 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Mon Feb 05, 2018 5:16 pm
Hi - after some advice...
After watching several videos on replacing a euro lock on a UPVC door, I went about measuring the cylinder to buy a replacement.
Things quickly went sour...the center screw is partly covered on both sides which is stopping me from removing the screw.
There is a a metal plate that runs the entire length of the door. Before I attempt removing this plate (some 16 screws) I want to be sure this is the right thing to do to access the center screw?
I have attached a photo for reference.
Thanks!
File comment: Metal plate covering center screw
PostPosted: Mon Feb 05, 2018 5:37 pm
Has thanked: 701 times
Been thanked: 2027 times
i would assume the lh/top screw in the picture will release the lock assuming its in line with the screw hole on the bottom off the lock :dunno:
PostPosted: Mon Feb 05, 2018 6:03 pm
Has thanked: 1206 times
Been thanked: 1096 times
That's how it looks to me too. The "metal strip" contains parts of the lock mechanism, and at least if it's like mine and the lock goes through the "handle box" behind the strip, you would need to remove the lock anyway to remove it.
PostPosted: Mon Feb 05, 2018 6:33 pm
If you look closely, I can't unscrew that top screw as there are two small "plates" either side preventing it from coming out...
PostPosted: Mon Feb 05, 2018 6:55 pm
Has thanked: 1531 times
Been thanked: 3852 times
Hss drill bit about 8 mm should do it . just enough to access the screw.
PostPosted: Mon Feb 05, 2018 6:57 pm
if thats the case is must be designed to screw in after the plate goes on
so iff you take the plate off insert the securing screw after you put the plate back on
PostPosted: Mon Feb 05, 2018 7:24 pm
Seem weird to deliberately make it that way. :dunno:
You can only try to dismantle it, or use wine~o's method.
As I said with mine the "strip" is a channel, and it holds the strip inside that works the extra locking points.
PostPosted: Mon Feb 05, 2018 7:41 pm
I'm guessing a double door ...
PostPosted: Mon Feb 05, 2018 8:53 pm
my only thought about drilling
may damage the screwhead and swarf may get behind the plate
now not overly worried about the swarf as its not a moving part but worth thinking about
PostPosted: Mon Feb 05, 2018 10:22 pm
Has thanked: 40 times
Been thanked: 1429 times
Ever thought it might not be that screw, but the middle one?
What happens if you undo the middle one?
PostPosted: Mon Feb 05, 2018 11:44 pm
Has thanked: 764 times
Been thanked: 857 times
Yup. It looks like the middle screw is holding the plate over the rest of the stuff.
PostPosted: Tue Feb 06, 2018 9:58 am
Has thanked: 70 times
Been thanked: 143 times
No, s-e is saying, the middle screw IS the lock barrel screw. The angle of the picture deceives the eye.
PostPosted: Tue Feb 06, 2018 10:34 am
Has thanked: 643 times
Been thanked: 1815 times
Yes, I would try the middle screw, I think the others are to do with the multi point lock system.
Painting with BIN
PostPosted: Tue Feb 06, 2018 11:34 am
Has thanked: 16 times
Been thanked: 97 times
Is there a makers name on the strip? that might help.
PostPosted: Tue Feb 06, 2018 11:40 am
go to the key
draw a line 5mm up from the bottom off the lock
use a square sheet of paper or envelope
slide up the edge off the door until you line up with the mark
and thats the screw to loosen it :lol:
