Yohanson Junior Member
Posted: Mon Feb 04, 2008 7:27 pm Post subject: Equalizing valve or pressure relief valve |
Hi
Don't know which one to get - Bath shower mixer is connected to a gravity fed tank that supplies the hot water, All the cold is directly fed from the rising main which causes a big problem when trying to get an imbetween water temperature for the shower.
I was advised to either install a pipe to header tank and use this to cold feed or use a pressure reducing valve.
I don't really know what to do with regards to the pipe bit and the water tank is quite small and only seems to fill a third of the way ?
As for the pressure relief valve, I done a little reading and you can get an equalizing valve which is far more expensive but seems to be more orientated around my problem.
Can anyone help me please |
