It is currently Mon Jul 23, 2018 2:30 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Sun Jul 23, 2017 10:12 pm
Has thanked: 1 times
Been thanked: 1 times
Help needed...
I have recently removing some light fittings from An upstairs loop and can't remember how one of them was wired before. Unusually I have 4 wires..
1 Black - I assume to be neutral
2 green - earth
3 red - perm live
4 red with grey sleeve - assume switched live
I'm assuming this is the last fitting on the loop but don't know how I should be connecting for a new light fitting with standard block for live neutral and earth.
I have tried a couple of ways but so far thrips the box everytime...
All help appreciated
Regards
Andrew
PostPosted: Sun Jul 23, 2017 11:06 pm
Has thanked: 44 times
Been thanked: 1297 times
Never assume anything. It is up to the person who wired it what does what. Since assuming has not worked, I can only suggest you get a multi meter and find out what does what.
PostPosted: Mon Jul 24, 2017 8:58 am
That's fine but even when the light fitting is not connected the loop trips so I can't even test the wires as it won't allow me to get the power on ....
PostPosted: Mon Jul 24, 2017 7:24 pm
You don't need the power on
PostPosted: Mon Jul 24, 2017 7:29 pm
Has thanked: 1452 times
Been thanked: 3725 times
:welcomeuhm:
Pics please.
And when you say
"That's fine but even when the light fitting is not connected the loop trips so I can't even test the wires as it won't allow me to get the power on "
what do you have connected and what other work has been carried out on this circuit ?
PostPosted: Mon Jul 24, 2017 8:03 pm
Approved Electrician
Has thanked: 163 times
Been thanked: 566 times
That suggests that one of the other light fittings you have changed is the cause of the problem.
PostPosted: Mon Jul 24, 2017 8:53 pm
Been in the loft to investigate and have found a spur powering some led lights in the bathroom via a separate switch.. could this be the issue as it's a single spur off the upstairs loop ??
PostPosted: Mon Jul 24, 2017 8:59 pm
Look at it from the flip side.
Have you touched the bathroom lights? no, well its not them then.
PostPosted: Mon Jul 24, 2017 9:16 pm
No but these were fitted on an old fuse board and worked fine prior to me having a new consumer unit fitted. (I know that might sound behind the times) so the sensitivity of these is greater than the old board.
For this message the author Eavesy31 has received gratitude : multiman
PostPosted: Mon Jul 24, 2017 9:38 pm
So are you now saying these bathroom lights do not work either, or is this "20 questions"
If you really want help, tell us exactly what you have done, touched or "investigated" other wise we could be here for months.....or decide its beyond your ability and call an electrician in to come and see what error there is.
PostPosted: Mon Jul 24, 2017 9:51 pm
Nothing works as everytime I power on the board trips.. sorry if you think I'm being vauge but essentially I didn't have any issues prior to the new consumer unit being fitted even with the lights removed I was still able to use bathroom and other bedroom lights.
Essentially I have 5 lights 3 with 2 way switches and this spur with a plug socket on the end powering the low voltage leds. Clearly I'm no expert but I'm guessing the spur is the issue???
PostPosted: Mon Jul 24, 2017 10:23 pm
Has thanked: 201 times
Been thanked: 127 times
Did the spark who fitted the cu not test after fitting it or did they work after cu fit but before you fitted new fittings?
For this message the author Ktuludays has received gratitude : multiman
PostPosted: Mon Jul 24, 2017 10:26 pm
Any of us can only go by what you type.
First you said
But you then said
I am sorry, but unless you tell us everything you have done (as I asked previously) I would suggest you call an electrician in.
Guessing what is wrong will get you no where, you need to understand the basic principals. (or get some one in who does)
PostPosted: Mon Jul 24, 2017 10:41 pm
I'm not sure what more I can tell you... lights worked fine before cu unit was changed I removed 2 lights before the Cu was changed and other lights worked fine. Then cu was replaced with new breaker box. Turned on a light that was fitted and working before and it trips. I thought the trip might be caused by not having lights fitted hence why I came here to ask advice. Clearly I'm not guessing just suggesting what I think might be the issue.
PostPosted: Mon Jul 24, 2017 10:45 pm
It sounds like it could be an issue with shared neutrals being used. This would cause a trip. The spark wouldn't have been able to test as the fittings were disconnected at the time of cu install. Having said that you may have wired them up as they were originally but that doesn't mean it's correct. I think you need to get a sparkie in to find the fault
For this message the author Ktuludays has received thanks - 2: Dave54, Eavesy31
