Ultimate Handyman Home
Emergency repair kit
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
Yohanson
Junior Member
PostPosted: Thu Feb 07, 2008 8:49 pm    Post subject: Emergency repair kit Add User to Ignore List Reply with quote
Does anyone have any good suggestions regarding a flap on situation when say for instance, a pipe bursts in the house or even worse, the main water feed stop tap springs a very fast leak just under the tap itself.
I was thinking about this the other day in bed and now i'm worried for some reason.
Would it be possible to cut the pipe very quick and stick a quick fit stop end on the pipe - or would the pressure be too much to do this ?
cheers
Back to top
Bludall
PostPosted: Thu Feb 07, 2008 9:41 pm    Post subject: Add User to Ignore List Reply with quote
I think I've seen burst repair kits on the plumbing aisle of our local B & Q.
Never be afraid to ask, that's how we learn.
Back to top
View user's profile Send private message Yahoo Messenger
gday2uk
Junior Member
PostPosted: Thu Feb 07, 2008 11:04 pm    Post subject: Add User to Ignore List Reply with quote
find out where the stopcock is in the road?
Back to top
Yohanson
Junior Member
PostPosted: Fri Feb 08, 2008 7:49 am    Post subject: Add User to Ignore List Reply with quote
Cheers - I think that's the best option (external stop tap) Just didn't want the neighbours complaining if it's turned off. Will get a tool for a store it safe.
Back to top
PostPosted: Fri Feb 08, 2008 10:35 am    Post subject: Re: Emergency repair kit Add User to Ignore List Reply with quote
cheers
This is almost impossible with mains pressure water.
What you can do is use a push fit isolating valve, make sure it is in the open position and push this onto the pipe and then when it is firmly fitted close the valve. You will get soaked doing it, but it is possible.
Locating the outside stop tap is the best idea and check it regularly to make sure it turns on and off, never open it completely- always close it back half a turn when fully open or it may sieze up. Havinf a stop tap key handy is also a good idea!
DIY | DIY Video
Back to top
Yohanson
Junior Member
PostPosted: Fri Feb 08, 2008 4:43 pm    Post subject: Add User to Ignore List Reply with quote
Appreciate the info and UHM - Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
