It is currently Thu May 24, 2012 12:44 am
 Post subject: electricty meters
PostPosted: Sun Nov 20, 2011 6:37 pm
Has thanked: 34 times
Been thanked: 5 times
Hi all
Can anyone advise me on the best way to install an additional meter to monitor the electricity usage of an out building?
the power will be from a domestic supply for an outbuilding which has a normal meter. a few sockets 5 and a couple of lights
swa cable buried 600mm from the house 15 mts or so !
thankyou in advance
 Post subject: Re: electricty meters
PostPosted: Sun Nov 20, 2011 7:41 pm
Has thanked: 134 times
Been thanked: 468 times
refurbed meter ?? :dunno: :dunno:
http://www.electricmeters.co.uk/recondi ... prepay.htm
For this message the author big-all has received gratitude : starterforone
PostPosted: Sun Nov 20, 2011 7:42 pm
Has thanked: 62 times
Been thanked: 217 times
Any 'meter' will do (and you can get all versions via eBay) which just connect in series with the live wire (with a connection for the neutral for powering the meter of course). Use a input/output cable of at least the same cross-sectional area as the main (in your case, your SWA cable) cable.
This post may contain nuts
For this message the author kellys_eye has received gratitude : starterforone
PostPosted: Mon Nov 21, 2011 3:54 am
Has thanked: 6 times
Been thanked: 96 times
If less than 13A then there are loads of plug in meters you can even program in the price. Image over 13A you will need to pay more.
For this message the author ericmark has received gratitude : starterforone
PostPosted: Mon Nov 21, 2011 10:33 am
Has thanked: 7 times
Been thanked: 66 times
I used http://www.tlc-direct.co.uk/Products/RDCRED60.html on my last rewire. The landlord wanted to keep the garage for himself and it seemed the cheapest way of paying the tenants back for the electricity he used.
For this message the author OnlyMe has received gratitude : starterforone
PostPosted: Mon Nov 21, 2011 12:31 pm
Thankyou for the responses!
I just need to know what side of the (new) meter should I use the RCD unit?
do I go into an RCD unit from the consumer unit then to the meter and to the sockets etc! or do I take a supply from the consumer unit to the meter then into an RCD unit?
cheers!
PostPosted: Mon Nov 21, 2011 1:32 pm
The meter should come before any powered device but AFTER the break at your main indoor consumer unit. Mount it either in your house or down in the workshop. Doesn't matter really.
PostPosted: Mon Nov 21, 2011 7:26 pm
:cheers:
