Ultimate Handyman Home
Electrical switch & moving oven question
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK
comfortably_numb
Member
PostPosted: Sun Oct 05, 2008 8:41 pm    Post subject: Electrical switch & moving oven question Add User to Ignore List Reply with quote
Hi Folks.
I would like to move my gas cooker over slightly. There is enough gas pipe but it would move the oven beneath this switch which i understand is for electric oven (if one should be fit in the future).
The switch itself does nothing but believed to be "live".
The landlord is not happy for it to removed or relocated. Is there a way of keeping this switch & that will allow the safe movement of the cooker beneath it ??
Back to top
IDontBelieveIt
PostPosted: Sun Oct 05, 2008 8:50 pm    Post subject: Add User to Ignore List Reply with quote
If I understand you correctly - yes.
Purchase a blanking late to suit the back box of the Cooker Control Unit (CCU) the thing in your picture.
Isolate all power by turning off the main swich at the fuse box.
Remove the CCU.
Remove the three cables (live, neutral and earth) from the CCU and connect these to a large choc-block (3 terminal).
Best wrap a bit of insulation tape about the entire choc-block making sure that no whiskers are poking through! Pit the chock-block into the back box and fit the blanking plate.
Job done.[/b]
Never lie - that way you don't have to remember what you said.
Back to top
comfortably_numb
Member
PostPosted: Sun Oct 05, 2008 8:59 pm    Post subject: Add User to Ignore List Reply with quote
Thanks for response Thumbright
Can i ask .... If i just permantly isolate it at the fuse box & leave the CCU as is ,,, The cooker has a glass hood that when lifted would cover the switch when in use ... would this be ok ???
Back to top
IDontBelieveIt
PostPosted: Sun Oct 05, 2008 9:14 pm    Post subject: Add User to Ignore List Reply with quote
Not really as heat and fats will penetrate the CCU and if someone else comes along in the future and re-connects the cooker circuit and hence activate the CCU then a fire could result due to fatty deposits inside the CCU.
If, on the other hand you leave the premises, someone else moves in and wants an electric hob/oven then any sparky will be able to reactivate the whole thing quite quickly.
Back to top
comfortably_numb
Member
PostPosted: Sun Oct 05, 2008 9:18 pm    Post subject: Add User to Ignore List Reply with quote
OK thanks ... i appreciate your feedback
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK All times are GMT
Page 1 of 1
