Ultimate Handyman Home
Electrical help
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK
gaz
Junior Member
PostPosted: Fri Feb 09, 2007 11:50 pm    Post subject: Electrical help Add User to Ignore List Reply with quote
Just knock two rooms into one for a bigger kitchen. I have bought Eight downlights, no transformer needed, and when the kitchen is done 3 undercabinet lights.
I was planning to daisy chain the spots from the existing light, but not sure about the cabinet lights. can i tee off from the existing lighting?
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Fri Feb 09, 2007 11:58 pm    Post subject: Add User to Ignore List Reply with quote
I think the lights should in parallel, rather than in series, which is what daisy chaining will result in.
to acheive this, connect all the lives together, and all the neurals together, in the same place.
www.hintonheating.com
Back to top
markysparky
Electrician
PostPosted: Sat Feb 10, 2007 1:27 am    Post subject: Add User to Ignore List Reply with quote
Always better to have the cabinet lights on a seperate switch to the main lights. If you can do it that way do. You might regret it later on if you don't!
Back to top
View user's profile Send private message Send e-mail Yahoo Messenger
jason123
PostPosted: Sat Feb 10, 2007 10:59 am    Post subject: Add User to Ignore List Reply with quote
I agree with HH, in series, one bulb blows, all eight will go out, in parallel you will see exactly which one has blown. It may be worth considering splitting the lights further, maybe in pairs over work areas individually switched, Im just thinking of some versatility in the lighting arrangement.
Stella Stella Stella oy oy oy
Back to top
gaz
Junior Member
PostPosted: Sat Feb 10, 2007 2:35 pm    Post subject: Add User to Ignore List Reply with quote
I would prefer to keep the cabinet lights seperate sparky, so should i spur of a socket?
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK All times are GMT
Page 1 of 1
