It is currently Wed Jan 23, 2019 8:16 pm
PostPosted: Sun Apr 15, 2018 5:23 pm
Hi there, was this problem fixed, I have similar problem. In our laundry room there is a double plug socket. I had dryer and washing machine on and whatever happened it tripped switch in meter cupboard. The plug socket has a 13amp fuse, and in the kitchen there is a blank fuse switch. I have checked and both of these fuses work. My appliances work if I run in an extension lead. But the socket isnt working, I must say when I remove front of socket the wiring looks messy, bits of tape here and there. I could upload picture if that helps. Im tempted to turn off electric trims wires and re wire, trouble is there isnt much slack in the cable, what are your thougts?
PostPosted: Sun Apr 15, 2018 6:20 pm
UHM Super Moderator
Has thanked: 56 times
Been thanked: 92 times
:welcomeuhm:
As the OP hasn't been back since the end of 2012, I doubt if anyone knows what happened.
So I've given this it's own new thread.
Please don't dig up old threads.
Please read the forum rules.
http://www.ultimatehandyman.co.uk/how-to/forum-rules
PostPosted: Sun Apr 15, 2018 6:29 pm
Has thanked: 39 times
Been thanked: 1415 times
1) How did you determine that the fuses are still working?
2) What exactly tripped in the meter cupboard
3) Is anything else not working?
PostPosted: Mon Apr 16, 2018 1:26 am
Has thanked: 65 times
Been thanked: 548 times
I have the same problem, and to correct I know I need access to sockets and will likely need to lift a floor board or two. Some times you are lucky and you find it easy, some times it's a real pain.
For a ring final socket to stop working you need two independent faults. So one needs to test each socket to find out where the fault is. You can't test without meters, some times you can get lucky and you can open a socket and find the faults, but remember two faults, so will need testing.
