Page 1 of 1
[ 5 posts ] |
| Author |
Message |
Jason_H
Posted: Sun Oct 23, 2011 10:49 am |
| Newly registered Member |
Joined: Sun Oct 23, 2011 10:37 am Posts: 2 Has thanked: 0 times Been thanked: 0 times
Hi everyone
I have searched through as many forum posts as I can and now have a general idea of the answers to some of my shower questions but would really appreciate a pros specific advice.
The property is a studio flat, all electric no gas and is to be rented out to probably just one person. I am looking at the most cost effective solution for a shower, both buying/installing and running costs. My thinking is that as only one person will be living there an electric shower might be cheaper for them, rather than to heat up the hot water cylinder/immersion heater?. I understand that any shower rated 7.5kw or above will require a 10mm2 cable with the relevant sized RCBO.
1. Would an electric shower be cheaper to run than using a power/mixer shower with an immersion heater to heat the water?.
2. Mira appears to be the most recommended, I was looking at the Mira Sport but not sure whether to get the 9kw, 9.8kw or higher, is this a good, reliable model with out the bells and whistles of the Advance?
3. Is it that much more expensive per shower to run say a 10.8 kw than a 9.8kw or a 9.8kw than a 9kw?,
4. Will a 10.8kw/9.8kw flow be that much better at the same temperature than a 9.8kw/9kw?
5, The sparks I intend to use is qualified? but does not have Part “P”, does he need this in order to issue a certificate for the shower installation and overall electrical check of the studio?
Thanks in advance for your help.
| Top |
royaloakcarpentry
Posted: Mon Oct 24, 2011 12:27 pm |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
5.......he needs to be Part P or the other option is that you notify the council, he does the work and then the council inspect and sign it off.
It will be worth checking to see if the plumber you will be using is Part P registered as some of ours are.
| Top |
register or
log in
BillyGoat
Posted: Mon Oct 24, 2011 3:04 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1885 Has thanked: 77 times Been thanked: 130 times
2........depends where you get it from, I was told. The Mira in the DIY shops are supposed to be inferior quality. I've just purchased a Triton direct from their clearance page on their website. There is an R4 9.5Kw for 120 quid.....I'm happy with mine!
3........more expensive, yes - much more? Doubt it - you don't shower for hours, do you?
You said it's a flat - what size supply do you have? Is it a submain from a meter cupboard and how is it supplied (SWA, 25mm tails, etc). You need to take this into account BEFORE you purchase a shower. 10.5KW could require a 45 amp MCB maybe a 50!!
BG
| Top |
register or
log in
thescruff
Posted: Mon Oct 24, 2011 3:06 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39982 Has thanked: 187 times Been thanked: 2113 times
The boys will tell you Mira are far better than Triton
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Jason_H
Posted: Tue Oct 25, 2011 8:21 pm |
thanks for all your replies - very helpful
| Top |
register or
log in
Page 1 of 1
[ 5 posts ] |
