It is currently Thu May 24, 2012 12:28 am
 Post subject: Electric Damp proof
PostPosted: Mon Oct 10, 2011 9:13 pm
Hi All
Need some advice ( non expert, so plain english please!!!)
I have notied to damp batches on my wall, one on an extrenal wall and the other next to the front door on an internal wall. Both these patched are about 10" above the floor level, the one next to the door seems to spread from the door.
However I have an Electric damp proof in place which was installed before i purchased the house, how do i know if its working etc, it has a green light on. Any advice on the damp, could it be riasing damp
Thanks for you help and advice in advance
 Post subject: Picture added
PostPosted: Mon Oct 10, 2011 9:33 pm
This is next to my front door, my neighbours side is bone dry
Notice the two smaller damp marks above the the large ones
 Post subject: Re: Electric Damp proof
PostPosted: Mon Oct 10, 2011 10:02 pm
Has thanked: 125 times
Been thanked: 392 times
It looks like that is penetrating damp rather than rising damp.
What is the silicone like on the outside of the door frame?
Electro osmosis damp proof courses are normally very reliable and if the green light on it normally means it is working.
DIY | Donnas dream house
PostPosted: Mon Oct 10, 2011 10:03 pm
Can someone help me
I want to know where you think the damp might be coming from??!!
PostPosted: Mon Oct 10, 2011 10:22 pm
The door was badly fit i have re-done the silcone when i noticed them damp and so they were loads of gaps
Sorry what is penetrating damp?
PostPosted: Mon Oct 10, 2011 10:43 pm
Jack Of All Trades
Has thanked: 27 times
Been thanked: 55 times
penetrating damp is usually caused by a blockage in the cavity wall allowing damp to travel across the gap (cavity) between the outer and inner brickwork.
By eck! ©
PostPosted: Mon Oct 10, 2011 11:01 pm
Gadget wrote:
Penetrating damp is usually caused by a blockage in the cavity wall allowing damp to travel across the gap (cavity) between the outer and inner brickwork.
This wall is connected to my neighbours, so its an internal wall, should that matter?
( also my neighbours wall on the inside is bone dry
How do I fix it?
PostPosted: Tue Oct 11, 2011 5:44 am
The first thing to check is the seal between the door casing and the wall as it is likely that water is penetrating the seal between the two.
Users browsing this forum: Bing [Bot] and 1 guest
