It is currently Sat Jan 19, 2019 10:50 pm
 Post subject: EAC Fail
PostPosted: Mon Nov 27, 2017 7:42 pm
Has thanked: 61 times
Been thanked: 3 times
EAC Fail on Ford Fiesta 1.4 Ghia. Causes, preventions please?
 Post subject: Re: EAC Fail
PostPosted: Mon Nov 27, 2017 7:54 pm
Has thanked: 349 times
Been thanked: 1811 times
Common failure apparently - often needs replacement of the throttle body. Suggested fixes include cleaning the throttle body, checking the wiring/connections, lubricating the throttle pedal mechanism etc.
Dealer fix is £700-ish - off street garages will be substantially lower.
PostPosted: Tue Nov 28, 2017 10:43 am
Thanks. Started first time this morning, so hopefully it's nothing too serious.
PostPosted: Tue Nov 28, 2017 4:46 pm
Has thanked: 60 times
Been thanked: 625 times
EAC Fail on the fiesta is ultra common, It needs to be diagnosed correctly and not to throw parts at it - TB and throttle codes can be misleading and they need to be tested
worse case your looking a replacement ECU - But I would check with a main dealer if there is a ECU update for you car
iirc the ecu is next to the battery (2002-2008) can you read the part number from it ?
Edit. these are the 2 most common ecu's that fail
-2S6A-12A650-SE / S118107002F / 4ROS
-2S6A-12A650-SG / S118107002K / 4ROV
