It is currently Tue Feb 19, 2019 9:57 pm
Post new topic Reply to topic  [ 1 post ]
 Post subject: Dust Extraction Tubing
PostPosted: Sun Jan 28, 2018 2:27 pm
Has thanked: 14 times
I am looking to add a small amount of dust extraction to my work bench and am hoping for some advice regarding the diameter & material of the tubing.
The dust will be extracted by my Nikfisk Multi 30T vacuum which has a 35mm nozzle. I am planning on running the tubing on the underside of my bench and having a non permanent connector to the vacuum.
I would like to use clear tubing & elbows etc. (so I can see if it gets clogged) but am unsure of the diameter and material of the tubing i.e. PVC or acrylic & what effects the diameter of the tubing makes on dust extraction?
My beech workbench is supported by 48.3mm scaffolding so I ideally would like the tubing to be the same diameter to keep it hidden, but I realise this might restrict the suction.
I will be extracting wood dust and chippings from my table saw and pillar drill.
Many thanks in advance for your help!!!
Stophen.
