Ultimate Handyman Home
DSM Mist Coat before Farrow & Ball?
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum
roylec
Junior Member
PostPosted: Tue Dec 11, 2007 9:04 pm    Post subject: DSM Mist Coat before Farrow & Ball? Add User to Ignore List Reply with quote
I've had four rooms skimmed - Hallway, Lounge and 2 Bedrooms. Nice job, good spreader.
The plaster is about a week dry, there were a few small patches that were bonded first, probably about 15mm deep max.
I need to get started with the painting and would normally mist first with a 5:1 ratio of trade high opacity matt, like Dulux Supermatt (DSM), or perhaps the newer Fast Matt (never tried this so probably won't on this job).
The walls will be finished using a nice Farrow & Ball matt colour, a cream if you are interested..
Anyway, I heard stories that DSM is as sh*te under another paint as it is over the top of another paint. This doesn't make any sense to me, since DSM is only sh*te over another paint because it's meant to be applied to a bare surface like plaster - it shouldn't affect anything painted over the top. But F&B paints are expensive and I don't want to spoil it, so I thought I would offer it out for your opinion.
What do you think?
P.S. It may be that the chap who told me this is alluding to the traditional technique of misting using only the paint that you finish with. This method goes back before we had vinyl paint, so I've no idea if anyone still uses this rule today.
Back to top
Welsh Decorator
PostPosted: Wed Dec 12, 2007 1:21 am    Post subject: Add User to Ignore List Reply with quote
roylec, welcome to the mad house!...... only kidding! Laughing Hello
Supermatt is very good stuff, ignor what you have been told, it's crap!
You could probably use the F&B thinned as your first coat, as the wall have only been skimmed, not full coated, personaly I would go for a 25 to 30% thin, if you use the F&B as a mist, otherwise, 50/50 non vinyl as a mist coat, but given it's only been re-skimmed, F&B first and finall coats, I've never had any problems at all in the past doing this with F&B paints.
Must admit, I have never had any had any trouble with Super matt, under or over existing paints, Flatt matt is the doggies under carrage as a finish paint, what is your mate on about? scratch Thumbright
Back to top
View user's profile Send private message Yahoo Messenger
fordy
Member
PostPosted: Tue Jan 22, 2008 12:49 am    Post subject: Add User to Ignore List Reply with quote
why use f&b as a mist coat? Its bloody expensive
If its new plaster your gonna need 3 coats anyway!!
Mist with the glidden vinyl matt cheap and cheerful or supermatt whatever takes your fancy. watererd down of course
Back to top
paintycait
PostPosted: Tue Jan 22, 2008 1:01 am    Post subject: Add User to Ignore List Reply with quote
Fordy..what are you talking about? you don't mist new plaster with vinyl...
Paint - including F&B...which BTW is not that expensive - is still the cheapest decorative product per sq metre for any surface anywhere in your whole house.
Phone F&B and ask them what they recommend then your back is covered. F&B is very expensive if it fails and you have to paint it all again at your own expense.
www.decoratescotland.com
Back to top
View user's profile Send private message MSN Messenger
bobbie-dazzler
PostPosted: Tue Jan 22, 2008 7:03 am    Post subject: Add User to Ignore List Reply with quote
I always mist new plaster with a contract matt, like gliddens or supermat, even if its skimmed, but loads of decorators argue with me that its okay to use a thinned Vinyl as a mist coat also.
Admittidly I did use it once, and it turned out okay, but I still would rather mist with a contract, there are so many different theories about it,its no wonder DIYers get confused.
When I first met my Mr Right, I didnt realise his first name was Always.
Back to top
handyman
PostPosted: Tue Jan 22, 2008 7:54 am    Post subject: Add User to Ignore List Reply with quote
most of my painting jobs a F&B at the moment Bang Head
Anyway, always use supermatt as the mist coat, and havent have any probs. Doing a few repaints now (2 years later) and these rooms have no problems that i can see.
Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................
Back to top
handyman
PostPosted: Tue Jan 22, 2008 7:56 am    Post subject: Add User to Ignore List Reply with quote
ps, a F&B shop have now opened in Wilmslow..........so I'm going to be using even more of the stuff Bang Head
Back to top
paintycait
PostPosted: Tue Jan 22, 2008 8:21 am    Post subject: Add User to Ignore List Reply with quote
Sorry Bobbie that was said slightly tongue in cheek, lot of controversy there. I would be lary of using cheap vinyl though.
Back to top
feva
PostPosted: Tue Jan 22, 2008 3:34 pm    Post subject: Add User to Ignore List Reply with quote
i use gliddens contract for my mist coat, ive never used vinyl matt for a mist coat, 'if it broke why fix it'
ive never heard of any one using vinyl matt as a mist coat till now
Back to top
handyman
PostPosted: Tue Jan 22, 2008 3:48 pm    Post subject: Add User to Ignore List Reply with quote
it say on the tubs of vinyl that you can mist coat with it. I found it kind of sat on top of the surface, and when dry, it scrapped off with your nail.
With non vinyl, it seems to sink into plaster much more, and passes the 'nail' test.
Did it once, never again. On the other hand, the paint hasnt failed, and that job must have been 3 years ago
Back to top
Welsh Decorator
PostPosted: Tue Jan 22, 2008 3:53 pm    Post subject: Add User to Ignore List Reply with quote
It's the viynl content thats the trouble.
I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it!
Back to top
Kernel32
PostPosted: Tue Jan 22, 2008 4:28 pm    Post subject: Add User to Ignore List Reply with quote
A mist coat, is a mist coat.
The problems arise when the plaster isnt dry.
Back to top
handyman
PostPosted: Tue Jan 22, 2008 5:17 pm    Post subject: Add User to Ignore List Reply with quote
and theres a whole new topic on the wording on the supermatt tub.................'still drying plaster'
Back to top
Welsh Decorator
PostPosted: Tue Jan 22, 2008 6:02 pm    Post subject: Add User to Ignore List Reply with quote
I don't know where the confusion over this comes from scratch
If the plaster is new, or un painted, then a non viynl mist coat is used, if it is still drying out, but not obviously wet, again, a non viynl paint, that is what it was desigend for, if it's paperd, then a glue size is used.
Where does it say (anywhere) about the use of PVA, for anything scratch that stuff started out life as a woodworking adhesive :!: sure it is used for certain jobs in plastering, but never in painting, or paper hanging.
I would really love to know just when this 'super, cure all' became a part of the decorators standard kit scratch
The times that people say 'do I need to PVA first', if I had my way PVA would be sent to room 101. angry
Back to top
handyman
PostPosted: Tue Jan 22, 2008 6:15 pm    Post subject: Add User to Ignore List Reply with quote
well wd, as i said, theres confusion with sealing new plaster when dulux trade vinyl says to seal new plaster with it watered down 20%
Explain that one Laughing
http://www.icipaints.co.uk/products/info/dulux_trade_vinyl_matt.jsp
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum All times are GMT
Page 1 of 9
