-> Plastering Forum |
| Author |
Message |
skiking Senior Member
Posted: Sun Feb 25, 2007 6:44 pm Post subject: |
| I'm with slugster here. Taking it all back to bare wall is quite easy, just messy. Doing dot'n'dab is also straight forward - I did it for the first time a couple of months ago and I was supprised how straightforward it is. No specialised tools - altho' a board lifter at about £6 was v.helpful. To put battons up will require you to get them level, evenly spaced out and very well secured to the brick - quite a bit of effort and the cost of the wood. Then you've got to make sure you secure the plasterboard corretly to these battons. |
| Back to top |
mysterio84 Junior Member
Posted: Sun Feb 25, 2007 7:14 pm Post subject: |
| just for the record we are not going to be doing this ourselves, so we would leave it to the experts, if we said we want to use battoning do you think they would be ok with that? |
| Back to top |
Posted: Sun Feb 25, 2007 7:18 pm Post subject: |
Sorry, I thought this was a DIY job.
Ask them to quote for both methods then see which is cheaper and quickest. For a 'pro' I'd suspect they'd go for battons as it less messy and you'll be picking up the bill for the timber and it'll be quicker for them. |
| Back to top |
Posted: Sun Feb 25, 2007 7:24 pm Post subject: |
sorry again i should have made this clear, i think we would prob go for the battons as this will be quicker and a lot less messy.
i hope the probems with door frames wont be to difficult to sort out. |
| Back to top |
Slugster Senior Member
Posted: Sun Feb 25, 2007 7:37 pm Post subject: |
| Quote: |
| Taking it all back to bare wall is quite easy, just messy. |
+1 to that
Sorry Bretty, I went off on one without fully understanding your position.
Can now understand and now I agree with Skiking.
Good luck with the renovation. |
| Back to top |
-dj- BANNED
Joined: 17 Jan 2006 Posts: 451 Location: south manchester
Posted: Sun Feb 25, 2007 7:42 pm Post subject: |
batons are no quicker than dot n dab!!
if it was me doing the job i would get you to knock it back to brick yourself then i just dot and dab it! |
| Back to top |
ultimatehandyman Site Admin
You may find that it is cheaper to get a firm in to do this rather then do it yourself!
I once needed a full house drylining and I got a quote for materials and then asked a guy that I knew, he did it cheaper than I could buy the stuff for as he got a good trade discount! _________________ DIY | DIY Video |
| Back to top |
Posted: Sun Feb 25, 2007 7:58 pm Post subject: |
Cheaper than DIY . Even by TP 2 tier pricing I'm supprised at that (not doubting you, never been quoted for the job). None of the materials are that expensive to start with. £6 for 8x4 pb, £4 a bag of board finish, adhesive £6 a bag. |
| Back to top |
Posted: Sun Feb 25, 2007 8:02 pm Post subject: |
| skiking wrote: |
It was a full three bedroom terrace, all ceilings and all the walls.
On some of the walls I had foam backed plasterboard and on the ceilings I had foil backed. There was a lot of plasterboarding and they bought it from a firm in Bolton, that does only plasterboard. I was getting it priced from B&Q and so it worked out cheaper for them to supply and fix it! _________________ DIY | DIY Video |
| Back to top |
Posted: Sun Feb 25, 2007 8:05 pm Post subject: |
I should also add that they made it look very easy and had all the boards up in one day. They mixed a big bath full of adhesive and just threw blobs at the wall and then attached the sheets.
They overboarded a downstairs ceiling and seemed to hit the joists without even measuring
It was great to watch  _________________ DIY | DIY Video |
| Back to top |
Posted: Mon Feb 26, 2007 5:54 pm Post subject: |
| we have made a few calls and we are having a few dry lining companies come and give us quotes. |
| Back to top |
Posted: Wed Feb 28, 2007 8:16 pm Post subject: |
firstly i would like to thank everyone for their input, the response has been fantastic!
well today we had our first dry liner around to give is a quote, now please dont shoot me down as this is our first quote and we have no idea what it should be.
we are having 10 good size rooms dry lined with battoning, this includes the ceilings, also we are having two hall ways and one room dry lined using bonding (because the walls are in good nick) and the ceilings here as well, the downstairs hallway is about 25 yards long and the upstairs hallway is about 15 yards long
il post pictures of the rooms just so you can get a rough idea of the size of the rooms.
The quote we were given was £5800. Obviously we have more companies to come and give us a quote so please dont shoot me down saying i am stupid if this quote is !!
The downstairs lounge
The hallway just inside the front door
the hallway next to the stairs
The next two pics are of the same room from different corners of the room
This is the rest of the hallway downstairs.
This will be the downstairs bathroom
This is the Downstairs kitchen
The next two pics are of the same room.
2 pics of upstairs lounge
This is one of the bedrooms upstairs and is about 12ft by 15ft
This is the full hallway upstairs
this is the same hallway but from the other end
This the upstairs bathroom
Ths upstairs kitchen
This is two pics of the back bedroom.
The final 2 pics of the loft conversion
sorry for the amount of pics but this is so you can get a orugh idea at how big the house/rooms are. |
| Back to top |
Posted: Wed Feb 28, 2007 8:30 pm Post subject: |
That is a big house
Great pictures, thanks for taking the time to post them  _________________ DIY | DIY Video |
| Back to top |
Posted: Wed Feb 28, 2007 9:01 pm Post subject: |
yes it is a big house, its like a tardis inside and we have plans that are currently being looked at by our local council to see if they will allow it to be turned from a single dwelling to two apartments. This will be our 4th renovation, the amazing thing is that this house a terraced house i was really surprised when i walked in through the front door.
this is a our most recent renovtion that we have had up for sale since september. For some reason we just cannot sell it!!we have had so many people look at it, but no one is taking the bait!!
http://www.homesonview.co.uk/Scripts/ShowProperty.asp?CompanyID=WATTBRIG&AgencyID=WATTBRIG&ID=WBP01718 |
| Back to top |
Posted: Wed Feb 28, 2007 9:07 pm Post subject: |
| brettytopbanana wrote: |
That is a very nice house!
I once struggled selling on a year or two back, the estate agents said it was like a showhome but It took me months and in the end I dropped it in price from £180k to £140K I think If I had been living there that I would of sold it much quicker and for an higher price. _________________ DIY | DIY Video |
| Back to top |
