Page 1 of 1
[ 5 posts ] |
| Author |
Message |
54aardvark
Posted: Fri Feb 08, 2008 10:11 am |
| Senior Member |
Joined: Thu Jan 10, 2008 5:53 pm Posts: 1033 Location: MONTROSE Has thanked: 3 times Been thanked: 18 times
Got an odd one for you - Garage conversion being done by another guy, he's just tacking up and (for some reason) I've been asked to come in to tape & skim - no probs so far.
However he won't do the ceiling because he says that as it is timber (sitting on nice solid joists) that the plasterboard will flex and tape & skim will crack.
Punter isn't fussed whether the ceiling is plastered or not as its going to be an office - but it'll be cold and look c**p
Is he talking b*******s, or am I missing something?
| Top |
Posted: Fri Feb 08, 2008 10:21 am |
| Site Admin |
Joined: Sat Jul 16, 2005 8:06 pm Posts: 20637 Location: Darwen, Lancashire Has thanked: 125 times Been thanked: 392 times
It depends on how far apart the joists are?
If they are too far apart then he could be correct. Noggins also should be installed where joints do not fall inline with the joists or joints accross the joists.
| Top |
register or
log in
54aardvark
Posted: Sat Feb 09, 2008 8:43 am |
| Senior Member |
Bog standard 400 centres - seems OK to me.
Not overly concerned as punter is happy with the plan, just wanted to check in case there was something I could miss in the future.
| Top |
register or
log in
leebwk
Posted: Sat Feb 09, 2008 9:57 am |
| Senior Member |
Joined: Fri Dec 01, 2006 8:16 am Posts: 1591 Location: Oxford Has thanked: 3 times Been thanked: 30 times
Hi Aardvark,
Yes i think he's talking b******s aswell, you would be better off insulating, tacking and skimming the ceiling, you could add additional noggins if required but if the joists have been there a long time then i doubt there will be anymore movement.
_________________ If you think nobody cares, try missing a couple of payments..
| Top |
register or
log in
Mooncat
Posted: Sat Feb 09, 2008 10:47 am |
| Senior Member |
Joined: Sun Dec 23, 2007 4:11 pm Posts: 9928 Location: Wales Has thanked: 33 times Been thanked: 42 times
My office/bedroom ceiling has 75 x 50 rafters. I fitted 50mm polystyrene foam between them, leaving a gap above, then plasterboarded and taped/skimmed. One or two cracks in 22 years, but nothing that bothers me.
_________________ I started out with nothing, I still have most of it. Directmail scam information site: http://astrocat.proboards.com/index.cgi?
| Top |
register or
log in
Page 1 of 1
[ 5 posts ] |
