Page 1 of 1
[ 8 posts ] |
| Author |
Message |
wolfman310
Posted: Thu Nov 17, 2011 5:17 pm |
| Newly registered Member |
Joined: Thu Nov 17, 2011 4:58 pm Posts: 2 Has thanked: 0 times Been thanked: 0 times
Hi There,
I am hoping you can help me. We have a pipe outside our house that looks like it is copper, but it has a plastic cover over it and it is constantly dripping. We don't know what it is, but our water bill is very high but unsure if this is the drip that is causing it or whether we have another issue elsewhere.
The house is only 3 years old and the plumbing has always been a massive issue.
i have attached a picture, would anyone know what it might be? (I can't see the otherside of the pipe, i am unsure where it goes)
Thanks for your help.
| Attachments: |
File comment: Picture of pipe outside with plastic cover over it.
| Top |
BillyGoat
Posted: Thu Nov 17, 2011 5:21 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1885 Has thanked: 77 times Been thanked: 130 times
So what IS on the other side of the wall?
| Top |
register or
log in
wolfman310
Posted: Thu Nov 17, 2011 5:36 pm |
The other side is the downstairs toilet and hall with stairs. On that wall would be the small radiator, and a small corner sink. There is boxed in pipes along that wall, but think that's for the water pipes to toilet.
If it is slightly further along then there is another radiator in the hall, or you then have the stairs, under the stairs is an empty walk in cupboard.
| Top |
register or
log in
Beachcomber
Posted: Mon Nov 21, 2011 9:39 pm |
| Senior Member |
Joined: Thu Jul 30, 2009 5:26 pm Posts: 833 Has thanked: 17 times Been thanked: 58 times
As the house is only 3 years old, can't you get this looked at under any guarantees?
_________________ If at first you don't succeed - remove all evidence that you tried.
| Top |
register or
log in
Posted: Mon Nov 21, 2011 10:03 pm |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10508 Location: redhill surrey an auld reekie laddie Has thanked: 134 times Been thanked: 468 times
whilst a dripping noise may use water if it lost say 500ml an hour 12L a day you will waste around 4.5 tonnes off water a year or around £7-8 a year power showers /baths use quite a bit a ton off water is 1000L and costs about £2
_________________ we are all ------------------still learning
| Top |
register or
log in
rovert
Posted: Mon Nov 21, 2011 10:09 pm |
| Senior Member |
Joined: Mon Nov 23, 2009 12:35 am Posts: 171 Location: Blackpool Lancs Has thanked: 7 times Been thanked: 17 times
Its not a toilet overflow pipe? Where someone has concealed the outlet by plugging it into a short lengh of 40mm waste.
| Top |
register or
log in
Colour Republic
Posted: Mon Nov 21, 2011 10:18 pm |
| Senior Member |
Joined: Thu Jul 29, 2010 2:08 am Posts: 1570 Location: Brighton & Hove Has thanked: 144 times Been thanked: 217 times
I'd be surprised if it was a WC overflow seeing as the house is only 3 years old.
I suspect the 40mm waste around it is to protect it from cars maybe??
Does the house have a combi boiler? if so do you have to top the system up on a regualr basis.
Could really do with knowing 'exactly' what is on the otherside of the wall in that location
| Top |
register or
log in
tomplum
Posted: Sun Nov 27, 2011 7:18 pm |
| Senior Member |
Joined: Sun Oct 31, 2010 7:56 pm Posts: 371 Location: wigan lancs Has thanked: 11 times Been thanked: 69 times
If its not a combi blow off, It might be a unvented cylinder warning pipe, in which case you need to get it seen to,
| Top |
register or
log in
Page 1 of 1
[ 8 posts ] |
