It is currently Wed May 23, 2012 11:54 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 13 posts ]
PostPosted: Sat Jan 01, 2011 3:38 am
Has thanked: 8 times
Hi
Have been trying to do a bit of DIY over this break, laying floor and new toilet etc
Have 2 holes to drill, to secure toilet to porcelain floor tiles, on concrete floor
Looking for a cheap drill bit which guess will not be used again, toilet did come with floor fixings but believe they were 12mm maybe bigger. Dont fancy trying to drill this big and crack the pan!
JUst looking to drill maybe 7mm hole through toilet base holes and secure with rawl plugs and 2 1/2 inch screws? Does this sound ok and then silicone base?
Have tried with a decent tile drill bit but dont get anywhere, but understand i need a diamond one, which appear really pricey for 2 holes
Also should i get clear or white silicone for the base, floor is black and walls are white
Thanks in advance
PostPosted: Sat Jan 01, 2011 12:10 pm
Has thanked: 2 times
Been thanked: 327 times
What toilet style is it......close coupled or a back to the wall pan??
For this message the author royaloakcarpentry has received gratitude : guy999
PostPosted: Sat Jan 01, 2011 1:26 pm
Has thanked: 14 times
Been thanked: 135 times
get some bosch multi construction bits for drilling tile
PostPosted: Sat Jan 01, 2011 2:01 pm
royaloakcarpentry - Its just a close coupled toilet.
speed - thought they had to be diamond tipped not normal bits, my usual ones dont work
Found a diamond drill bit on ebay Dewalt DT6039 7mm Diamond Tile Drill Bit £13, but would this drill through the concrete ok?
PostPosted: Sat Jan 01, 2011 2:22 pm
Has thanked: 3 times
Been thanked: 16 times
What type of drills have you tried? I've done something similar in the past, using a 10mm drill through the tile, then very carefully with an 8mm masonry bit afterward. Looks less than perfect, but ok under a concealed fitting.
PostPosted: Sat Jan 01, 2011 5:30 pm
Has thanked: 7 times
Been thanked: 128 times
If it's a porcelain tile the only way to drill it is with a drill intended for porcelain, (that's why they make them cos nothing else will really do it), once through the tile a standard SDS masonry bit will be best to drill the concrete.
For this message the author ayjay has received gratitude : guy999
PostPosted: Sat Jan 01, 2011 8:36 pm
Put toilet into position and mark position of holes onto the floor. buy an Armeg drill bit suitable for porcalein from screwfix, cost about £20 or so. move toilet out of the way and drill tile, then drill concrete with masonry bit. Put toilet back and screw down, using brass or stainless screws.
If you have fixing blocks for the toilet then put toilet into position and draw around it, then fix the blocks into position. Toilet back and fix.
Finish off with white silicone around the toilet and floor. Dow Corning 785 also available at screwfix. Don't skimp with any other cheap alternative silicone.
For this message the author royaloakcarpentry has received thanks - 2: guy999, lagi
PostPosted: Sun Jan 02, 2011 12:33 am
royaloakcarpentry- Thanks for your help again. However should i drill 11mm hole as kit supplied or just go with a smaller 7mm brown rawl plug
PostPosted: Sun Jan 02, 2011 4:32 pm
What kit was supplied with the toilet............plug and screw with cap or plastic fixing blocks and screw with cap.
PostPosted: Sun Feb 06, 2011 12:14 am
hi
used a drill bit from toppstiles £6, no probems at all
PostPosted: Sun Feb 06, 2011 1:31 pm
Tiling Expert
Has thanked: 6 times
Been thanked: 10 times
Cheap throwaway diamond hole bits from hong kong, i use these people cheaper than chips, last about 10 holes each, arrives approx 5 days http://stores.ebay.co.uk/THK-Diamond-Tools-3 you won't beat these prices!!
Natural stone specialists mosaic, porcelain and ceramics
PostPosted: Sun Feb 06, 2011 2:01 pm
M3....................Sacramento, just had a peek on the site. The hand polishing pads are less than half the price for 7 compared to what Nichols and Clark charger for 2.
The hole saws are very cheap also.
Have you used much of there stuff or just the drill bits?
PostPosted: Sun Feb 06, 2011 8:33 pm
Tiling Expert
used the polishing diamond abrasive pads on my polisher, and diamond holesaws, good products, good price, as cheaper than chips :wink:
