It is currently Sun May 26, 2019 4:48 am
PostPosted: Thu Oct 04, 2018 9:21 am
Has thanked: 10 times
Been thanked: 4 times
Morning Guys,
I have the above controller for my Worcester-Bosch 42CDi and yesterday I went to turn on the heating for the first time in a while and noticed after turning up the heating temp the " red alarm" led was lit on the digistat and even though the green led on the digistat flash and the boiler started to kick in the red led alarm stayed on and the boiler never started the heating, now I have hot water so that is all ok and theres no fault codes coming up on the boiler, but my question is is the red led alarm staying on because there is a fault with the digistat or because there is a fault with the wireless controller? I have changed the batteries on the wireless controller and gone through the "learn mode/pairing" the two units again although its been fine for over 5 years.
Any ideas where the fault may be? The digistat, the wireless controller or the boiler? :help:
PostPosted: Thu Oct 04, 2018 11:45 am
Has thanked: 840 times
Been thanked: 941 times
Usually, but not always I end up replacing the whole lot when the red led is on.
Awful stats imo.
Dave
www.drlgas.co.uk
PostPosted: Thu Oct 04, 2018 2:49 pm
Thanks Gas4you,
What stat would you recommend?
PostPosted: Thu Oct 04, 2018 8:40 pm
I tend to fit the Honeywell stats or programmable stats.
Not perfect, but then what is these days, but simple to use.
Dave
www.drlgas.co.uk
PostPosted: Mon Oct 08, 2018 8:07 pm
Gas4you
I have the receiver and controller paired up and now when I turn up the temperature up on the controller the red light flashes on the receiver then the green light comes on but the boiler doesn’t fire up the heating? Is there a way of bypassing the receiver and wiring it up so the heating comes on all the time and then I control the heating on the boiler? :help: as I’m bloody freezing :cb
PostPosted: Mon Oct 08, 2018 10:13 pm
Only if you feel competent to remove the receiver wiring in the boiler wiring block and link the two terminals out
Dave
www.drlgas.co.uk
PostPosted: Mon Oct 08, 2018 10:18 pm
I’m confident enough, is it the black and yellow wires go into the same terminal?
PostPosted: Mon Oct 08, 2018 10:34 pm
Has thanked: 41 times
Been thanked: 1480 times
A guess, no, because they are already in the same terminal.
Also it depends on what colours who ever installed it chose to use.
A picture would help
PostPosted: Mon Oct 08, 2018 11:36 pm
Has thanked: 85 times
Been thanked: 81 times
Refer to Dia 8 on page 28 or 30 depending on which revision of the installation manual you have.
Connect a link across LS and LR on connector block ST10 in the boiler.
As the others have said please only attempt this if you feel competent, as you are dealing with 240v mains on those terminals, so make sure the boiler is fully isolated from the mains before carrying out any work.
PostPosted: Sun Oct 14, 2018 7:08 pm
I can’t for the life of me get the front control blank plate off didn’t want to damage it is there a knack to it?
PostPosted: Sun Oct 14, 2018 8:32 pm
Don't you lift it up by the tab with the arrow on it?
PostPosted: Sun Oct 14, 2018 10:25 pm
Before you do anything else Please download the appropriate manual from the link below.
https://www.worcester-bosch.co.uk/profe ... structions
Follow carefully the instructions on page 30 or 28 (depending on manual revision) referring to ‘Access to Electrical Connections’
As you can see you remove a screw from the retaining bracket to enable you to lower the control panel.
Step 8 refers to block ST10 connections.
PostPosted: Sun Jan 20, 2019 12:16 pm
Hi guys just to let you know as I forgot to update this post. I change the capacitor on the receiver circuit board. Cost me £3 off eBay and heating been a treat since b
