Page 1 of 1
[ 9 posts ] |
| Author |
Message |
potatoes 2727
Posted: Mon Dec 12, 2011 1:18 pm |
| Newly registered Member |
Joined: Mon Dec 12, 2011 12:52 pm Posts: 16 Has thanked: 9 times Been thanked: 1 times
hi can anyone help. i am relocating my rad in my living room and need to drain my c/h system. i have know drain cock on any of the radiators and i cannot see any valve on the boiler itself to drain the system. all i can see is the valves to attach the filling loop to, thats only if a can get the thing drained. any help would be great.
| Top |
thescruff
Posted: Mon Dec 12, 2011 1:25 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39982 Has thanked: 187 times Been thanked: 2113 times
Is there a spigot thing on any of the rad valves.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
potatoes 2727
Posted: Mon Dec 12, 2011 2:22 pm |
no none at all. am i right in saying there must be a drain valve on the boiler. i cant c how else i would drain the system, and i am also in a 2nd floor flat som theres now drain off outside like u get on some houses.
| Top |
register or
log in
thescruff
Posted: Mon Dec 12, 2011 2:25 pm |
| OAP |
If there's really nothing on the radiator or pipework, then you'll need to turn both radiator valves off, and drain the radiator into a bowl.
Once it is empty you can attach a hose and open the valve.
| Top |
register or
log in
potatoes 2727
Posted: Mon Dec 12, 2011 2:37 pm |
I have emptyed the rad, cant attach hose to the valve to big. Its annoying but think i might have to be patient and drain it all through the valve into a bowl, cant c any other way. going to have one last look on all the rads and combi to c if av mist something.
| Top |
register or
log in
thescruff
Posted: Mon Dec 12, 2011 2:45 pm |
| OAP |
Can you post a pic of a valve
| Top |
register or
log in
LordCross
Posted: Mon Dec 12, 2011 9:45 pm |
| Senior Member |
Joined: Wed Nov 30, 2011 11:58 pm Posts: 398 Has thanked: 9 times Been thanked: 62 times
tapomatic! then add a compression t and drain off after.
you could unscrew the tail out of the rad and use that on the end of your pipe?
| Top |
register or
log in
Razor
Posted: Mon Dec 12, 2011 9:53 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5140 Location: Northampton Has thanked: 76 times Been thanked: 372 times
Self cutting drain off is what I usually use or you could screw a washing machine hose to the valve
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
potatoes 2727
Posted: Mon Dec 12, 2011 10:09 pm |
Cheers everyone, i went for the option of draining the system through the valve itself. took long time to drain but hey. next time hopefully it is easyer.
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
