It is currently Mon Feb 18, 2019 10:16 am
PostPosted: Sun Jul 01, 2018 12:22 am
Has thanked: 72 times
Been thanked: 1 times
I had a 'long term' garage/workshop project on the go for a few years, widening and lengthening it !
I had a builder put up a 7m long and 2.5m high standard block wall a few years back on a deep concrete footing that I put in. He made a very neat job, which has 20mm mortar joints and he didn't put a DPC in as he said that can weaken the stability of the wall. Is 20mm OK and no DPC ? if I need DPC are there some sort of 'plugs' I can put at intervals along a low level (think I've seen these somewhere ?)
I am now constructing an opposite wall myself where I am using hollow (double, 220 thick) blocks for the first 4 tiers and then will go standard 100mm thick blocks up to 2.5m high (putting a shelf type feature at 4 tiers high ….). Should I be putting a DPC over the first line of blocks, and if so, and thinking of using some 'rebar' rods in some cavities and mortar filling for strength, do I penetrate a DPC with the rods ? And mortar thickness ?
Hope I have explained clear enough, being a jack of all trades and nowhere near a master of anything ??
many thanks in anticipation of guidance.
PostPosted: Sun Jul 08, 2018 5:53 am
Has thanked: 106 times
Been thanked: 303 times
Worry you have not had an expert response, if no damp showing in old wall then there is unlikely a local issue, 7mtr no columns is a stretch in my book, will also depends how you will tie the walls and roof, plus I always like a bit of rebar, horizontal in block mortar as well.
For this message the author aeromech3 has received gratitude : ChippyJoe
