Ultimate Handyman Home
Downlighters over a wood-burning stove
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK -> Lighting
jamesamor
Junior Member
PostPosted: Sun Jul 27, 2008 10:34 am    Post subject: Downlighters over a wood-burning stove Add User to Ignore List Reply with quote
Hi All,
I'm currently installing a wood burning stove into a builders opening, and am hoping to get some advice over the installation of downlighters above the stove.
My plan is to install a heatproof board into the chimney opening (below the register plate, but out of sight) and then put downlighters into this board.
The wiring will run above the board and out through the chimney breast (so will never come into contact with radiant heat from the fire itself)
My main question is which downlighters should i use? I know there are 'fire-rated' downlighters, but I think this is burn-time rather than 'heatproofness'. I am thinking about using halogen lights, just because their ambient running temperature is much higher, but have been told that their PVC housing can turn corrosive if heated for long periods of time.
(I am also thinking that I am thinking too much!!)
Any advice/suggestions gratefully received.
Relevant points:
- The clearance from the top of the fire to the downlighters would be 0.75m
- The clearance from the flue liner to the wiring&lights would be ~25cm
- The fire is a small 5kw fire
- Not sure what temperature will be maintained at the underside of downlighter... maybe I'll wait to measure this before I do anymore thinking!
Back to top
Rich-Ando
Approved Electrician
PostPosted: Sun Jul 27, 2008 11:22 am    Post subject: Add User to Ignore List Reply with quote
hi jamesamor welcome to the forum
i have done this myself a few times and never had any problems. i did use the fire rated fittings as it that is the best method.
i understand you are more concerned about the tarnishing from the heat. i have found that brass fittings & white fittings discolour over time. if you use the bright chrome fittings they do slightly. however, using the satin fittings such as brushed nickel (many are the same but called different from retailers) these tend to actually tarnish the least.
the only bit that confuses me is when you mentioned the pvc part scratch it's metal & glass.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK -> Lighting All times are GMT
Page 1 of 1
