-> Building Forum |
| Author |
Message |
westies2803 Junior Member
Posted: Sat Jun 09, 2007 7:27 am Post subject: Double glazed unit replacement. |
Looking for some advise on how to go about relacing some double glazed units that the seals have gone( condensation inside the units).
What I would like to know is whats the best way to measure the glass & what other materials do I require& any tips on what not to do.
Cheers.
Westies2803 |
| Back to top |
ultimatehandyman Site Admin
Posted: Sat Jun 09, 2007 8:13 am Post subject: |
Are the windows wooden or PVC?
If they are pvc remove the beading, this will be inside on 98% of pvc windows. You can pop the beading off using a wide scraper and hammer, once removed you can measure the window.
Or alternatively if you wish you could get the glazier to come and measure them for you, this could be the safest bet! _________________ DIY | DIY Video |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Sat Jun 09, 2007 9:54 am Post subject: |
if they are openers get some help and take the full window in to the d/glazing company [phone first]
temporary covering will be required _________________ we are all ------------------still learning |
| Back to top |
Wood Magnet Senior Member
Posted: Sat Jun 09, 2007 12:04 pm Post subject: |
Or get a mate to lob a brick through when it's dark and claim on your insurance.  |
| Back to top |
Posted: Sat Jun 09, 2007 2:14 pm Post subject: Double glazed unit replacement. |
Cheers guys,
The windows are John Carr wooden sash,
Big -all the problen is that I need approx 8 windows fixed so I think this might be just too much hassle.
Pitbull good idea, but I don't think my insurance company would believe me......ha ha ha.
Thank again guys.
Westies2803 |
| Back to top |
Borderglazer Member
Joined: 23 Oct 2006 Posts: 66 Location: Scottish borders
Posted: Sun Jun 10, 2007 1:09 pm Post subject: |
Hi Westies,
Easiest way to measure the units is measure from bead to bead (ie across the glass between the beads) and add 22mm is generally fine.
And check the unit make up ie 4-6-4 etc.
happy glazing
Joe (Borderglazer) |
| Back to top |
Borderglazer Member
Hi Westies,
happy glazing
| Back to top |
Posted: Sun Jun 10, 2007 3:08 pm Post subject: |
Thanks Borderglazer,
I'm sure it's really simple... but what is the unit make up 4-6-4 ?
Cheers.
Westies2803 |
| Back to top |
Borderglazer Member
Posted: Sun Jun 10, 2007 3:28 pm Post subject: |
the make up 4-6-4 means 2 panes of 4mm glass and a 6mm spacer bar between them,you will have to try and estimate the units overall thickness unless you can get the unit out to measure the make up through the sealing on the edge.
Feel free to ask anything else glass or glazing related and ill do my best to answer sensibly
Joe |
| Back to top |
