-> Plastering Forum |
| Author |
Message |
Edz Senior Member
Posted: Thu Mar 29, 2007 2:27 pm Post subject: Dot n dab virgin! |
After lots of research and looking at plastering DVD's, I'm finally plucking up the courage to get started on plastering. Trouble is that none of the DVD's I have seen show anybody dotting and dabbing.
Are there any important tips I need? Or is it just a question of PVA'ing the walls, spodging on the adhesive, and shoving the boards up against it?
I am just a trifle concerned that I might whurl through 3 or 4 rooms only to find someone saying, "blimey mate you should have done X oy Y", and find it all coming apart in a few weeks/months.
Or am I being over cautious? Cheers.  |
| Back to top |
You may not be able to see the full post including pictures unless you Register or Log in
skiking Senior Member
Posted: Thu Mar 29, 2007 2:56 pm Post subject: |
I'm no expert in dot'n'dab but your not far off. Just make sure your even with you're adhesive and that your boards are straight - especially the first - and that they are all level.
Just in case you haven't seen UHM's instructions click here |
| Back to top |
andy-p- pro plasterer
Posted: Sat Mar 31, 2007 6:12 am Post subject: |
when you offer up the p/b make sure there is some adhesive near the edge of the board all the way up, put more on than less if your unsure how much per board.
use a straight edge (feather edge) to bang on boards to make them flat, check with a spirt level, make sure in each corner it is square,
leave a 1mm gap in between each board or a p/b nail width.
If its brick or block no need to pva just stick on glue, its great stuff, sticky, if its a little dusty just wet the wall a little.
take your time and just mix enough stuff for 1 wall at a time, most important make sure everything is level,flat and square and you'll be fine
Hope that helps Edz |
| Back to top |
Edz Senior Member
Posted: Tue Apr 03, 2007 12:51 pm Post subject: |
Thanks for the info guys. I did a couple of rooms at the weekend and was well impressed with the results.
On a couple of corners where the walls run out I have some gaps (10mm or so) tapering down to nothing. Should I scrim these and let the multi finish take them up? Or should I swidge in a bit of bonding plaster while I have some mixed to fit the angle bead to the reveals, then scrim? |
| Back to top |
ultimatehandyman Site Admin
Joined: 16 Jul 2005 Posts: 14694 Location: Darwen, Lancashire
Posted: Tue Apr 03, 2007 12:59 pm Post subject: |
I'd put a bit of bonding in to be sure  _________________ DIY | DIY Video |
| Back to top |
Edz Senior Member
Posted: Tue Apr 03, 2007 1:01 pm Post subject: |
| Thanks. Will do. |
| Back to top |
