Ultimate Handyman Home
Doorway Flooring
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
skiking
PostPosted: Wed Feb 07, 2007 11:25 am    Post subject: Doorway Flooring Add User to Ignore List Reply with quote
Hi - I've knocked through a door way and installed the lining. Where the bricks were I need to fill in to join the 2 separate rooms. There is a height difference of about 1.5cm between the 2 floors. The gap where the bricks were is about 3cm deeper than the highest floor. I intend to lay tiles on the highest floor and intend laying wood (real or laminate, not sure yet) on the other floor
My question is how do I level off the gap and with what? Do I use normal cement and how do I overcome the difference between the two floor – do I try and slope it from one to the other ?
Thx
Back to top
PostPosted: Wed Feb 07, 2007 1:47 pm    Post subject: Add User to Ignore List Reply with quote
I would mix some sand and cement, perhaps 4-1 ratio by volume and use that. Then I would level it off to the lowest floor level and then try and get both floors level (ish) where they join when you fit the final floor covering.
DIY | DIY Video
Back to top
skiking
PostPosted: Wed Feb 07, 2007 2:49 pm    Post subject: Add User to Ignore List Reply with quote
Thx UHM. What I thought about doing was to keep most of the gap to the lowest floor level as you've suggested. Also, as the door will open towards the lowest floor I am going to step up to meet the higher floor at the point of where the door will fit into the middle of the lining and I'll use a strip where the two floors meet. This sound right ?
I hate to mention this bit....but do I need to PVA the floor before putting new cement down ?
Thx
Back to top
PostPosted: Wed Feb 07, 2007 4:35 pm    Post subject: Add User to Ignore List Reply with quote
That sounds good to me skiking Wink
I would not bother with the pva to be honest, but I don't suppost it will do much harm where it is!
DIY | DIY Video
Back to top
skiking
PostPosted: Wed Feb 07, 2007 6:03 pm    Post subject: Add User to Ignore List Reply with quote
Thanks for the advice :grin:
Back to top
Jaeger_S2k
PostPosted: Wed Feb 07, 2007 6:54 pm    Post subject: Add User to Ignore List Reply with quote
General Purpose Non shrinking grout.
That was the advice from my structural engineer.
Jaeger.
FSBF
Back to top
skiking
PostPosted: Wed Feb 07, 2007 6:59 pm    Post subject: Add User to Ignore List Reply with quote
GROUT ! Shocked Confused I thought that was for small gaps ie the joints between tiles
Back to top
Jaeger_S2k
PostPosted: Wed Feb 07, 2007 10:07 pm    Post subject: Add User to Ignore List Reply with quote
Laughing Me too. But 'tis true.
Do a search on Non Shrinking Grout.
Jaeger.
FSBF
Back to top
marksson
PostPosted: Mon Feb 12, 2007 10:51 pm    Post subject: Add User to Ignore List Reply with quote
Why not just use a latex levelling compound?
a. no shrinkage.
b. no need for pva or any other key.
c. sand/cement mix might not like being that thin.
d. stock item in any merchant
e. you can apply as thick or thin as you like (especially to keep the 2 levels right for differing floor finishes (add sharp sand for thicker applications)).
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
