It is currently Tue Apr 24, 2018 2:09 am
 Post subject: Door Stop Fitting
PostPosted: Thu Jan 18, 2007 8:46 pm
Where should a door stop be fitted when the door opens into open space and not against a wall
Moved to carpentry forum.
Duplicate post deleted.
Ozzy
 Post subject:
PostPosted: Thu Jan 18, 2007 9:17 pm
Has thanked: 662 times
Been thanked: 1897 times
ok ozzy i was answering this post when you moved it and cant find it now !!! :grin: :grin: :grin: :wink:
heres the answer anyway :wink:
the door stop always goes in the same place the thickness of the door away from the edge plus an extra 1mm on the hinge side and 0.5mm on the lock side
but allowing for slight discrepancys in fitting you dont attach the door stop untill the door is installed
knock a couple of nails into the frame to temporarily support the door so it cant fall through the opening whilst your shooting it in[fitting it to size]
 Post subject:
PostPosted: Thu Jan 18, 2007 9:30 pm
Gas/Heating Expert
Been thanked: 9 times
I thought he meant the door stop of the type that stps the door swinging too wide, like the rubber one that screws into the floor!
 Post subject:
PostPosted: Thu Jan 18, 2007 9:35 pm
yeh that would make more sence :grin: :wink:
ok the answer is 1" before the door touches the wall or any other fitment like the archatrave 'door handles ect
 Post subject:
PostPosted: Thu Jan 18, 2007 9:49 pm
Gas/Heating Expert
or/and to prevent the hinges being over opened... 8-)
 Post subject:
PostPosted: Fri Jan 19, 2007 10:52 am
Quote:
Thanks for the info, but the door opens out over and has a self closer fitted to the top. So if the door opens out over and you want the door to stop in line with hinge or just past this point, how far in from the loose end of the door should you fit the door stop.
 Post subject:
PostPosted: Fri Jan 19, 2007 11:13 am
Thanks for the info, but the door opens out over and has a self closer fitted to the top. So if the door opens out over and you want the door to stop in line with hinge or just past this point, how far in from the loose end of the door should you fit the door stop.[/quote]
 Post subject:
PostPosted: Fri Jan 19, 2007 12:56 pm
i would say assuming its a 30 inch door round about 20 to 28" away from the hinge stopping the door an inch before full travel
you also need to keep in mind the trip hazard from a badly placed door stop :cry: :cry:
