It is currently Tue Oct 23, 2018 6:22 pm
 Post subject: Door linings
PostPosted: Thu Oct 26, 2017 8:46 pm
Has thanked: 98 times
Been thanked: 351 times
Having removed a wall, coming out perpendicular from the one pictured, I now have a wall with a decent area (plastered) and a smaller area with 2 door linings...
As you can see from the picture, the finish on the big area is about 10mm proud of the door linings, but only about 8" to blend it in.
Not over keen on replacing the door linings, millions of cut nails into thermlites...
Is it a viable option to glue and pin on a piece of 25x10 or there abouts timber, plane and sand flush with the inside, then replaster to the relevant depth to keep the wall flat...
 Post subject: Re: Door linings
PostPosted: Thu Oct 26, 2017 9:04 pm
Has thanked: 402 times
Been thanked: 1455 times
Yes definitely: and if it's not the door hanging side I probably wouldn't even try and keep it flush, set it back 3mm and save yourself the trouble of planing it flush. Definitely glue it though, otherwise it'll shrink and always show a joint, (that'll need filling).
For this message the author ayjay has received gratitude : Hitch
PostPosted: Thu Oct 26, 2017 9:19 pm
No, its not the hinge side. Needs to be flush, surely, so when the architrave goes back on it looks right.
PostPosted: Thu Oct 26, 2017 9:41 pm
Has thanked: 999 times
Been thanked: 1874 times
What I do in this situation is use what I call a “full stop” I extend the door stop so it sits in line with the wall and the facing(architrave) will sit/nail on the edge(leaving a 2mm list) which covers the void and sits flush with the wall on closing side.
Hope that makes sense!
For this message the author steviejoiner74 has received gratitude : Hitch
PostPosted: Thu Oct 26, 2017 10:30 pm
If you're re-using the old arcs then yes, but, there should be an 8mm quirk from original door lining to the arc so losing 3mm of that wouldn't matter. Unfortunately a lot of chippies? just put the arcs on at what sometimes seem like random spacings.
PostPosted: Thu Oct 26, 2017 10:51 pm
So instead of a bit of 12x32 doorstop, use a bit of 12x70 (or whatever i need) as the door stop, covering the whole inside of the lining....?
PostPosted: Fri Oct 27, 2017 11:53 am
Yes,we have to do it often when fitting new linings to old openings as we generally buy them at 95,120 or 145 wide. We just go to nearest small size and put full stops on.
