It is currently Fri Jan 18, 2019 9:41 am
 Post subject: Door Chime/Bell Wiring
PostPosted: Thu Jan 18, 2018 11:33 pm
Hi All,
I'm new to this site so go easy on me :D.
My wired doorbell is not longer working and it seem to be the chime box that is faulty. I want to replace it myself, but cannot figure out how the wiring works. There is a door bell transformer, which is located next to the main fuse box, in the chime box, I can see 4 white wires, 2 which are joined together and connected to a terminal and the other 2 connected to seperate terminals....problem/question is if I buy i new chime box how do i know which wire goes where ?
I've attached pics to help.
File comment: Transformer
File comment: Chime Box
PostPosted: Thu Jan 18, 2018 11:48 pm
Has thanked: 212 times
Been thanked: 281 times
The two wires that are connected together, one of them is from the transformer, the other is from the bell push. The other wire from the transformer goes to one of the terminals, and the other wire from the bell push goes to the other terminal. Polarity is unimportant.
Like this:-
PostPosted: Fri Jan 19, 2018 12:00 am
Has thanked: 39 times
Been thanked: 1407 times
Or another way of saying it:
The two wires on the same terminal are only connected to each other, nothing else.
_________________________________________________________________________________
There is one other thing you should note.
The new door bell you intend to buy it must be the same voltage as the transformer you already have. So look at the transformer and see what voltage it is (probably 8v)
What ever you do buy, do your self a favour and don't buy a "wireless" one, 99% of them are just rubbish.
PostPosted: Fri Jan 19, 2018 5:19 am
Has thanked: 103 times
Been thanked: 303 times
Bell chime transformers often have several voltage tappings, be sure you choose the correct voltage for your new chime. More often I have found the bell push faulty than the chime unit, guess someone has checked by bridging the two terminals in the bell push.
PostPosted: Fri Jan 19, 2018 7:52 am
Thanks for all the replies ! They've been very useful. I'm pretty sure it's the chime as there a horrible burnt smell that came from it last night, also the doorbell button has a light which is still illuminated, which suggest its still working as well as the transformer ??
I've managed to get the instruction booklet for the replacement chime I am thinking of buying...any suggestion on how i would wire it in... I don't know where the wires come from as they are all white, so how do i know which wire goes to terminal 0,1,2, or 3 Apologies for the stupid questions.
File comment: New Unit
PostPosted: Fri Jan 19, 2018 8:48 am
As has already been said, it does not matter which way round the wires go.
As I said, the two wires on the same terminal are connected just to each other, nothing else, with that in mind, look at drawing #3 It has two wires, one connected to terminal 0 and the other connected to terminal 3 if you connect your new door bell like that it will work, PROVIDED the pair that are connected to each other (The two wires on the same terminal) you leave them connected to each other, and put a single piece of connector strip on them.
The other option is drawing #2 but since I guess you don't have a multi meter and know how to use it, I wouldn't recommend it.
PostPosted: Tue Jan 23, 2018 10:59 pm
Has thanked: 147 times
Been thanked: 212 times
I would try drawing 1 or 2 first. The chimes/coils are connected in series on the first two, safer if the output voltage of the transformer is too high. If it works then all well and good. If not then try connecting as drawing 3.
