It is currently Sat Feb 23, 2019 12:59 pm
PostPosted: Thu Jan 11, 2018 2:22 pm
Hi there
So for a university project i'm wanting to produce a working prototype of a portable hydro kinetic turbine. For this I need a small waterproof generator / gearbox. The generator can be ether AC or DC and the gearbox should be a ratio of around 1:10. I'm struggling to find a component which is fully sealed. :dunno: Is it better to attempt sealing / waterproofing a component my self?
Many Thanks
PostPosted: Thu Jan 11, 2018 8:02 pm
Has thanked: 349 times
Been thanked: 1825 times
Why? Presumably you're driving it through an impeller? - perhaps in a housing? and the shaft can remove the rotation energy to an 'external' alternator. I take it the output will be low voltage anyway (i.e. sub 55V)?
Placing any alternator in a suitable IP-rated box with a drive shaft accessed through a gland should be more than sufficient. As a student exercise maybe you could look into developing a magnetic coupling to transfer power through a plastic housing that is totally sealed?
PostPosted: Fri Jan 12, 2018 9:24 am
I was really wanting to produce an 'in-river' portable water generator, kind of similar to Enomad's 'Estream'. I was looking at maybe using a bilge pump as a generator..
The magnetic coupling is a good idea though, might be more difficult than a sealed generator...
PostPosted: Fri Jan 12, 2018 3:02 pm
Has thanked: 1207 times
Been thanked: 1098 times
Can I ask what the object of the exercise is?
It obviously isn't a completely new idea from the drawing you provide.
So is it a new use or way to use it?
Or is it to show you can design and build a submersible generator?
PostPosted: Tue Jan 16, 2018 9:18 am
Has thanked: 65 times
Been thanked: 553 times
The seal on a submersible pump points to the problem. They are normally ceramic on stainless steel with two seal separated and the void part filled with oil, which is changed on a regular basis, it includes assess holes where one can pressurise with air and test how long the air holds pressure.
The other seals on the pump are also critical, the last one I worked on the fault was in the supply cable, there was a pin hole in the cable and water was being drawn in through the cable.
The problem is heat, as it warms up it will try to push our air through the smallest of hole, then when it cools there is a part vacuum inside so it sucks in any water, in many items we simply don't try to seal, but have a vent tube at bottom of chamber so water is expelled first and air can replace it as it cools down.
The other idea is as said magnetic coupling, or making the electrical parts as epoxy blocks and smooth so even if water does get in it does no damage.
ImageNote what is on the flyght pump and this has no gear box, to add a gear box would be hard. One other way around is not to put the electric bit in the water Image The hydrolic submersible pump is very successful, it also allows variable speed to suit viscosity but the main thing any leak is a leak out, not a leak in.
As a test I would look at an old outboard motor, the gear box is under water but the engine is above water, bolting a generator onto the drive shaft near everything is already done, the whole idea of using ready made parts is common, look at the old Reliant cars and most the bits came from other cars, ford door handles, and Austin springs etc. It the idea works I am sure you could buy in the outboard bits to mass produce.
