-> Painting & Decorating Forum |
| Author |
Message |
comfortably_numb Member
Posted: Sat Dec 01, 2007 6:22 pm Post subject: Disguising or Painting the odd tile ?? |
Hi folks
I'm in a rented property & have a bathroom that has been tiled floor to ceiling with white tiles, only been up couple years & still look fine .. so no problem there.
The problem is, dotted around is a pattern tile that looks pretty naff ... Is there a way of disguising the pattern on these odd tiles by painting perhaps ?? |
| Back to top |
polecat Senior Member
Posted: Sat Dec 01, 2007 8:53 pm Post subject: |
hello CN you can paint tiles. You need to prime the tile with a propietry tile primer, you may be able to get these from the sheds and you can def get it from Brewers DDC etc. make sure you follow the instructions on the tin as it tells you about cleaning the tile and painting. you can finish of to suit. Oilbase would be my prefered choice being a bathroom although others may advocate something else. Dont really like painting tiles as it gen looks pretty naff but for one or two dotted about you can make them look quite good and get quite arty with it. paintycait may be able to give advice from that side of things. As an alternative there are a few places not a million miles from you that supply an adhesive sticker for tiles to change their appearance :grin: good luck mate  |
| Back to top |
Posted: Sat Dec 01, 2007 9:16 pm Post subject: |
Nice one ... Thanks Polecat  |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Sat Dec 01, 2007 9:25 pm Post subject: |
sticky back patern tile transfers thingys are easier to remove if the landlord is looking for an excuse to withold some of your deposit
http://www.berlinwallpaper.com/CoverTiles.htm _________________ we are all ------------------still learning |
| Back to top |
Posted: Sat Dec 01, 2007 9:36 pm Post subject: |
| Yep, i think transfers are the way forward :grin: |
| Back to top |
