It is currently Sun May 27, 2018 8:42 am
PostPosted: Thu Dec 08, 2016 5:06 pm
Has thanked: 13 times
Been thanked: 4 times
Moving next week and i have agreed to dump the very old gas cooker for new owner .....
one question before i do so, i suspect the current connection is not up to date anyway to modern standards as the cooker is ancient, but before i disconnect can some of you see photo attached and advise? do i remove black pipe from metal wall connection?
just want to do it safely..
thanks in advance!
PostPosted: Thu Dec 08, 2016 5:08 pm
Has thanked: 984 times
Been thanked: 1821 times
You need someone who is gas safe registered and qualified to work on gas appliances to do this job legally and safely.
PostPosted: Thu Dec 08, 2016 5:14 pm
OK
I stupidly thought you could disconnect an oven yourself
....i was doing him favour as he didnt want the oven, i may just try leave it in that case as i do not want to pay for gas engineer for an oven i am dumping
PostPosted: Thu Dec 08, 2016 5:18 pm
Has thanked: 311 times
Been thanked: 950 times
It's a bayonet fitting you can perfectly legally disconnect it yourself just grab the brass ring lift, twist and pull it out.
It's supposed to self seal but you might wanna check with soapy water
PostPosted: Thu Dec 08, 2016 5:25 pm
Cheers Razor! - ok so maybe ok then, i will look into it but maybe i will convince new guy to just leave it there till he brings new cooker in... maybe easier or il try get hold of a gas man friend of mine in time to come round....
PostPosted: Thu Dec 08, 2016 5:53 pm
gona try get gas man over to do me favour should be 5 min job for him! at least that way have peace of mind.... dont fancy doing soap tests etc etc.... cheers
For this message the author mjennings23 has received gratitude : Razor
PostPosted: Thu Dec 08, 2016 6:34 pm
Good choice, just because it's legal doesn't always mean you should :thumbright:
PostPosted: Thu Dec 08, 2016 7:36 pm
Apologies for giving incorrect advice :oops:
Is just the installation of a cooker that's deemed illegal to do yourself then razor? Even on a bayonet?
I was under the impression it had to be tested and certified,even(incorrectly) if disconnected.
PostPosted: Thu Dec 08, 2016 8:49 pm
No worries Steve it was well intentioned
The gas regs specifically allow for non gas muppets to remove self sealing connectors and bayonets. It's a favourite ACS exam question and isn't counted as 'work' on the gas :wink:
For this message the author Razor has received gratitude : steviejoiner74
PostPosted: Thu Dec 08, 2016 11:00 pm
Thanks for reassurance! Anything gas makes me nervous but as bayonet should be ok thanks guys
PostPosted: Mon Jun 19, 2017 1:43 pm
mjennings23 wrote:
thanks in advance!
It is quick connection plugin fitting. It is safe to plug it out on your own. If you are not familiarized with that maybe is better leave to new specialist, You could also pay for service and when new tehnat move in they will use service you paid. You can use removed Mod 2. they are cheap and fast.
PostPosted: Mon Jun 19, 2017 2:34 pm
Has thanked: 42 times
Been thanked: 621 times
For something as rare as moving a gas cooker I would always get someone in, while I trust myself on electrics, gas scares me and rightly so I think.
PostPosted: Tue Jun 20, 2017 7:20 pm
Has thanked: 647 times
Been thanked: 725 times
That connector needs a push up and a twist. You may need to remove it when the sausages fall down the back or if (in my case) the electric oven needs a repair (to which I chickened out).
