It is currently Fri Jan 18, 2019 9:46 am
 Post subject: Digital Thermostat
PostPosted: Fri Dec 08, 2017 12:26 am
Has thanked: 4 times
I want to install a digital thermostat for my central heating giving me more control setting temp, for example 20C between 6pm and 11pm, 15C between 11 and 7 and so on, WIFI would be nice but not essential.
Currently in the temperature is set by a Honywell manual wheel type thermostat and a Honywell ST9400C controller where one sets the timers.
There seems to be a lot of digital thermostats on the market ranging from £20 to a couple of hundred pounds.
Any help anyone as what I need?
Wasn't to sure where to post this.
 Post subject: Re: Digital Thermostat
PostPosted: Fri Dec 08, 2017 5:45 am
Has thanked: 103 times
Been thanked: 303 times
Just to start the discussion: you need a thermostat with Set Back for temperature, usually a programmable thermostat which would have time and temperature settings, as an example a Salus RT500RF but much more info required about your present set up for a Heating Expert to advise, as the Salus RT500RF receiver needs to be wired in correctly with your ST9400C or you change that too.
For this message the author aeromech3 has received gratitude : macski
PostPosted: Fri Dec 08, 2017 8:07 am
Has thanked: 840 times
Been thanked: 938 times
Simplest solution would be to replace the room thermostat with a Honeywell 907 and leave the heating set to continuous on your 9400c.
Or if you want wifi stuff, look at the Honeywell Lyric 6
Dave
www.drlgas.co.uk
For this message the author gas4you has received thanks - 2: aeromech3, macski
PostPosted: Sat Dec 09, 2017 3:41 pm
Thanks for the replies! and I see there os a sub central heating forum, I thought they might be but it was hiding when I posted.
Do thermostats need hard wiring?
PostPosted: Sat Dec 09, 2017 5:08 pm
Can be hard wired or wireless
Dave
www.drlgas.co.uk
