-> Carpentry/Joinery Forum |
| Author |
Message |
stealthdave Junior Member
Posted: Fri Aug 03, 2007 5:39 pm Post subject: |
thanks for the tip...
anywhere you'd recomend to get it from or local builders merchants? |
| Back to top |
skiking Senior Member
Posted: Fri Aug 03, 2007 5:54 pm Post subject: |
| Screwfix sell it here no idea how good/bad it is. |
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Fri Aug 03, 2007 5:56 pm Post subject: |
i would try a local builders merchants
I get mine of a friend who does landscaping _________________ Decking |
| Back to top |
Posted: Fri Aug 03, 2007 6:19 pm Post subject: |
| thanks skiing, typical, I need 16m and the roll is 14, hehe |
| Back to top |
dirtydeeds Craftsman Carpenter
Posted: Fri Aug 03, 2007 9:26 pm Post subject: |
| good job your decking is 1m wide and 16m long otherwise youd need even more for overlaps |
| Back to top |
Gadget Jack Of All Trades
Joined: 18 Dec 2005 Posts: 3557 Location: Whitley Bay
Posted: Fri Aug 03, 2007 9:36 pm Post subject: |
You'll get the heavy duty stuff at a good garden centre! _________________ By eck! |
| Back to top |
Posted: Sat Aug 04, 2007 8:09 am Post subject: |
| well the wood has arrived, the 4x4 posts have been treated. The 6x2 is graded wood and the guy told me it will be ok, but should this be treated too? |
| Back to top |
Posted: Sat Aug 04, 2007 10:12 am Post subject: |
yes all exterior wood should be tanilised _________________ Decking |
| Back to top |
panlid Senior Member
Posted: Sat Aug 04, 2007 10:45 am Post subject: |
stealth i dont like treating the 6x2 myself as it is not tanalised. the preserver you aplly yourself will last nowhere near as long as tanalised timber and remember you cant apply a fresh coat every couple of years due to access.
6x2 tanalised joists is a must imo. |
| Back to top |
Posted: Sat Aug 04, 2007 3:51 pm Post subject: |
Im in a bit of a stickign situation then.....
Can I tanatilise the wood myself?
Ive treated it now, if yes to the above is it ok to go over it.
P.S I'm only planning on staying at this house around 4 years |
| Back to top |
Posted: Sat Aug 04, 2007 5:10 pm Post subject: |
no tanilising if a pressure treating treatment and I dont know how it would work now you have put preserver on it,
what preserver have you used. how much timber have you bought?
I am surprised anyone would sell non tanilised timber for a decking project.
I for one wouldnt want to guarantee how it will last _________________ Decking |
| Back to top |
Posted: Sat Aug 04, 2007 5:22 pm Post subject: |
I bought just the outer frame and 3 internal joists, with another 8 to be bought and fitted next week.....
I have used some preserver that I used on the fence panels we have, and they still look like new two years on.......
I have been applying end grain preserver to the ends, would it be of any benefit to give the joists a coat of that (Sorry if thats a dumb question), as I have loads left after doing all me posts... |
| Back to top |
Posted: Sat Aug 04, 2007 8:11 pm Post subject: |
sorry dave but that preserver wont do any good, imo you need to chuck those joists and go and get some tanilised ones _________________ Decking |
| Back to top |
Posted: Sat Aug 04, 2007 8:16 pm Post subject: |
You could get them tanilised, ask your local timber merchant for info on who in the area can do it for you. I have no idea what it will cost though! _________________ By eck! |
| Back to top |
stevemastic Senior Member
Joined: 16 Jan 2006 Posts: 1181 Location: Cuckoo's nest
Posted: Sat Aug 04, 2007 9:55 pm Post subject: |
It's got to be pressure treated the guys are right , brush on stuff will only go a few mm max into you joists. _________________ Knock Knock Knock........ Stevies home!!!!
nil illegitimus carborundum |
| Back to top |
