-> Carpentry/Joinery Forum |
| Author |
Message |
wood4fun Senior Member
Joined: 02 Mar 2006 Posts: 314 Location: home of the 5 times european champions
Posted: Sun Apr 08, 2007 10:36 pm Post subject: |
| that will be nice for a bit of natural shade. good size deck must be nice to have a garden that size. |
| Back to top |
Gadget Jack Of All Trades
Joined: 18 Dec 2005 Posts: 3557 Location: Whitley Bay
Posted: Sun Apr 08, 2007 10:44 pm Post subject: |
The pic only shows about 66% of the garden size, and was much bigger again until I built the extension (top of pic) 16 years ago. _________________ By eck! |
| Back to top |
tim'll fix it BANNED
Joined: 18 Jan 2006 Posts: 2137 Location: Leicestershire
Posted: Sun Apr 08, 2007 10:56 pm Post subject: |
| panlid wrote: |
meanwhile in the real world get the router out  |
or just leave them cut square _________________ Decking |
| Back to top |
Posted: Sun Apr 08, 2007 10:59 pm Post subject: |
| owen wrote: |
| ultimatehandyman wrote: |
What size spacing would you recommend between the deck boards?
I was thinking of using some small angle brackets to fasten the boards to the joists rather than screwing through them, something like this but galvanised- |
UHM you have too much time on your hands if you can be arsed using those brackets for putting deck boards down! ;-)
You can get purpose made clips for fixing boards with no visible surface fixings, i have not used them so don't know if they are any good.
I allow about 4-5mm between boards, i usually knock a big nail through a piece of wood and use the nail as a spacer. |
i use my number two posi screwdriver for the spacing, it has a handle so it easy to pull out of the deck afterwards.
And lets me sensisble hear this is softwood timber treated by pressure to maybe 1/2mm if you are lucky, it is gonna last 10 years max if you are lucky so where you place the screw really has no bearing on where it will rot _________________ Decking |
| Back to top |
panlid Senior Member
Posted: Mon Apr 09, 2007 8:28 am Post subject: |
| tim'll fix it wrote: |
| panlid wrote: |
or just leave them cut square |
again, in the real world if you want them rounded just get the router out  |
| Back to top |
ultimatehandyman Site Admin
Posted: Mon Apr 09, 2007 12:29 pm Post subject: |
Looks good Gadget  _________________ DIY | DIY Video |
| Back to top |
Posted: Thu Apr 19, 2007 9:16 pm Post subject: |
I started the decking on Tuesday and so far the first deck joists and noggins have been fixed and the posts for the second deck, which is slightly higher then the first deck.
I'm surprised how long it takes to fit almost 40 square meters of decking  _________________ DIY | DIY Video |
| Back to top |
skiking Senior Member
Posted: Thu Apr 19, 2007 9:18 pm Post subject: |
You need to concentrate the mind to get things done quicker....you've obviously got other distractions these days  |
| Back to top |
Posted: Thu Apr 19, 2007 9:20 pm Post subject: |
I keep trying to concentrate, but I'm aching everywhere from fastening the joists and noggins to the ledger and the deck posts
| Back to top |
Posted: Thu Apr 19, 2007 9:22 pm Post subject: |
perhaps you need a rub down....do ya know anyone  |
| Back to top |
Posted: Thu Apr 19, 2007 9:24 pm Post subject: |
| skiking wrote: |
Thanks for the offer, but you will make Handy Angie Jealous  _________________ DIY | DIY Video |
| Back to top |
stealthdave Junior Member
Posted: Fri Aug 03, 2007 1:57 pm Post subject: |
apologies if this has been asked before but...
my b and q book states that I should put down a mebrane then cover with 40mm of gravel. Looking at the handy man guide they have landscape fabric with a bit of gravel? Why not 40mm.....?
Cheers |
| Back to top |
Posted: Fri Aug 03, 2007 4:36 pm Post subject: |
you only need a bit to stop it moving about _________________ Decking |
| Back to top |
Posted: Fri Aug 03, 2007 5:29 pm Post subject: |
thanks tim....
is landscape fabric and a builders membrane virtually the same thing then? |
| Back to top |
Posted: Fri Aug 03, 2007 5:31 pm Post subject: |
by builders membrane do you mean polythene DPM
if so then no, landscaping fabric lets the water through
the trade name for it is Terram 1000
dont buy the thin stuff from B&Q _________________ Decking |
| Back to top |
