It is currently Fri Apr 26, 2019 5:06 am
 Post subject: Decking posts
PostPosted: Sat Nov 03, 2018 12:00 pm
Has thanked: 1 times
Hi All,
I am going to be fitting some raised decking for my brother in law. It is a large area, 5.5m by 7.5m. How far apart should I lay the posts? I was thinking 1m per post but not sure if that is too close?
Thanks in advance
 Post subject: Re: Decking posts
PostPosted: Sat Nov 03, 2018 12:35 pm
Has thanked: 234 times
Been thanked: 192 times
Do you mean the joists?
Either 400 or 600mm centres are the norm
PostPosted: Sat Nov 03, 2018 6:07 pm
Sorry not the joists, the posts going into the ground to support the frame
PostPosted: Sat Nov 03, 2018 6:37 pm
Ok, 1 metre should suffice then. I did a similar job recently and had 4 posts postcreted in over 4.2m. Solid as a rock.
PostPosted: Sun Nov 04, 2018 12:02 am
I am going to put a ledger bolted to the outside of the wall. Do you think 18 posts will be enough? 3 rows of 6 from the wall ?
Because of the size what would you suggest would be the best way to lay the joists?
PostPosted: Sun Nov 04, 2018 5:35 am
That should suffice yes.
If the boards are thick enough then 600 centres should be ok.
